Does anyone know if a 99 Ex would have come from factory with a LSD. We bought the car new and everytime i do a E-brake burnout both wheels spin..... [&:]
__________________
99 Ex CAI, header, high flow cat, rear section exhaust, cam gear, fuel rail with gauge, FPR, short thow shifter, few body mods, and some stereo work, and more to come......
Explain posi every time i do e-brake burnout. I know i didn't ever do a LSD and every other fwd car i ever did e-brake burnouts only does one wheel peels. Is it a freek??????
__________________
Whats the use of a LSD if i get equal traction from both wheels as it is in a strait line. Seems like a waist of $800+ to buy a part that is suppsosed to do just that give me better traction.
__________________
The LSD is a huge improvement for cornering. When I put one in my old SI, WOW!!!
Auto-Xing was awsome, start getting a little understeer and just stomp on the gas and she would pull right back into the corner. Freaking amazing. Still not that great of str8 line though. Tires would spin when hitting VTEC.
__________________
Buy your parts from........Speed6motorsports.com
pick 2: reliable, cheap, fast
Not really interested in auto-xing so guess it's a good thing i didn't buy one. If i want better traction off the line i will buy the traction bars lakewood makes for the civic. Which can also be set up for auto-xing if need be to plant the tires in the corners.
__________________
LSD upgrade is only for the very serious. Youd have to do a tone of work to a single slammer to need one I think.
Maybe both are spinning becuase theres not a ton of extra HP going to em. I know as I did more and more the peg leg got worse and worse. I dont really remeber having a one legger stock.
HMMMMMM I dunno
__________________
yeah, lsd made a huge improvement, i swear by them now. most companies will give you a deal if you upgrade to an lsd tranny when buying a swap. i got the lsd tranny option for only 300 extra
some older front drive autos have a awkward drive axle. One side is longer than the other. Than means that one side will torq mor than the other. one side would grip sooner and your car would veer to one side or the other. but this has been fixed for newer cars
__________________
Why bother when we have rokets?
