Go Back   HondaCivicForum.com > General Automotive > General Civic Talk
Reply
Old 02-26-2008, 05:38 PM
imshirazy imshirazy is offline
Send a message via AIM to imshirazy
Default 15000 mile oil?
Is this true? Mobil 1 advertises it on their highest synthetic but it seems too good to be true, any thoughts?
__________________
burntheplanets.com/forum
my website!
Sponsored Links
Old 02-26-2008, 05:44 PM
LarsonSi_0091 LarsonSi_0091 is offline
Send a message via AIM to LarsonSi_0091 Send a message via MSN to LarsonSi_0091
Default RE: 15000 mile oil?
im not sure i have seen it avertised before also but im like you it almost seems that way. if its not i would wanna change my filter though
__________________
Cars:
91 CRX Si- race car (boosted)
90 CRX Si- DD with a mini me swap
Old 02-26-2008, 06:43 PM
95civic1.6l 95civic1.6l is offline
Thats wrong. The motor needs new oil every 3000 miles on a honda. It should be changed regardless of what advertisements say. Are you willing to risk your motor over it? thats the real question. Because if it blows up or starts running ****ty, You can't blame them
__________________
ARE YOU IN NEW ENGLAND, Check out the List, we want to have a meet!
http://www.hondacivicforum.com/m_418142/tm.htm
YOU Drink! YOU DRIVE! YOU LOSE!!!!!
Old 02-26-2008, 07:28 PM
paulide paulide is offline
My 2003 owners manual says to change the oil every 10,000 miles, and change the filter every 20,000 miles. I think the manfacturer knows what to reccomend. '03 EX.
Old 02-26-2008, 07:38 PM
DelawareDon DelawareDon is offline
I'm 65 years old and am a genuine "car guy,"...having owned over 145 different automobiles since I was a Sophomore in college. About 10 years ago, I spent almost all my spare time for well over a year reading all I could get my hands on about engine oil and oil change frequency. I came to the following conclusions:
1. The 3000 mile oil change interval is a myth perpetuated by the oil companies to get you to buy more oil. It is 1960's thinking...and they are counting on the fact that old practices die hard.
2. Synthetic blends offer longer protection than straight "dino" oil, and pure Synthetics offer the best protection of all.
3. There are synthetic oils on the market that will go well beyond even a 15,000 mile oil change interval. For example, Amsoil produces a synthetic oil that is designed for 25,000 mile change intervals. Interestingly enough, several years ago Amsoil ran a test on some of their long-distance synthetics, and used a tractor trailer as one of their test vehicles. The truck ran over 400,000 miles without an oil change, and when they tore the engine down, they found no significant wear. However, they did change oil filters at regular, specified intervals, and simply added oil that was lost when the filters were changed.
4. If you are going to use pure synthetic engine oil and plan on going beyond 5000 miles between oil changes, make sure you are also using an extended life filter. Mobil 1 makes one that is guaranteed for 15,000 miles. Amsoil makes one that is guaranteed for 25,000 miles.
I know that I will probably get flamed for this, for there are those who still swear by the traditional view that oil needs to be changed every 3000 miles (If it was good enough for my father, it's good enough for me syndrome). All I can say to them is; Be my guest. If you want to put more money in the oil companies bankroll, go to it!
Personally, I use Amsoil 5W30 pure synthetic and Amsoil extended life filters. I change both at 15,000 mile intervals. My 04 LX engine sounds as good as the day it left the showroom floor....burns absolutely no oil between changes, and delivers 41 mpg highway and 35 mpg city.
PS: When is the last time you saw anything on any of the Civic bulletin boards about an engine failing because someone didn't change oil at 3000 mile intervals? I regularly read at least 6 Civic forums and have never seen a post relating to oil change frequency and engine failure.
__________________
DelawareDon
04 Civic LX Sedan
Old 02-26-2008, 08:22 PM
It will still run but what do you think your engine is going to look like when you pull the oil pan off and rip apart that motor? I am going to school for automotive technology and your oil gets dirty when its in the motor your oil filter gets cloaged full of gunk debree and other things like that. the oil relief valve inside of it is going to open up and shoot dirty oil through your motor. And for your its good enough for me bull**** that you are chanting. Why is it then that people that mechanics that i know who have been in the business a long time say it should be changed at 3000 miles? And why is it i can take apart motors at school and you can see all the muck and gunk that can come from it? You are running your oil to the point where its barely lubricating. What color is your oil when it comes out? Super black? If what you say is true then when you do your oil change it should come out clear just like it went in.
__________________
Old 02-26-2008, 08:24 PM
o yea don't forget about your best friend called heat breakdown
__________________
Old 02-26-2008, 11:31 PM
Live_4it Live_4it is offline
another note to that is older engines I believe need changes more often. Every time I drain my oil after even 3000 miles I see specs of metal. Imagine how many specs of metal shaveing's will be circulating through the engine after 15k miles. I would rather be safe than sorry you know. I would pay the extra money to know that sludge and metal bits aren't clogging up my engine.
__________________
Old 02-26-2008, 11:51 PM
reconstyle reconstyle is offline
Old 02-27-2008, 12:12 AM
Quote:
ORIGINAL: 95civic1.6l
If 3k is what you need to be doing, then find me a service schedule for a honda that says to change the oil every 3k....
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
