Idle issue??? JRSC D16Z6
Login | |
Idle issue??? JRSC D16Z6 - 2/26/2008 6:54:21 PM
94HCBOB369
i am mechanically inclined, but new to imports. I have a 94 civic ex, mods include; jackson racing supercharger (running 6 lbs of boost), JR boost timing controller, cold air intake, magnaflow header back exhaust, msd ignition, and no mods to ecu. used as daily driver. Problem: the car, when cold, will fluctuate in rpm rythmically until the car warms up. the rpms will go from <1000 up to about 2300 and back again. over and over until i seriously consider offing myself because of how annoying it is. What i think it is: i think, since there are no mods to the ecu to let it know there is boost, when the rpms get to around 2300, a little boost is making the engine want more fuel. the ecu says no and cuts fuel, once rpms get below normal idle, the ecu starts to add fuel, then the whole cycle starts over. Question: is there any after market anything to solve this annoyance? or am i wrong in my theory? has anyone with similar mods experienced this same issue? any help would be a big help.
RE: Idle issue??? JRSC D16Z6 - 2/26/2008 7:02:12 PM
95civic1.6l
hello. Welcome to HCF. JRCS's are made so they can run without having to tune the ecu. But I bet sov would be able to help you more because he has had one before and i have never had one. But Lots of hondas do this. Its trying to get to normal operating temperature as fast as possible. My honda does it and all i have is a SRI. But what your saying is that once it warms up it goes back down?
_____________________________
ARE YOU IN NEW ENGLAND, Check out the List, we want to have a meet! http://www.hondacivicforum.com/m_418142/tm.htm YOU Drink! YOU DRIVE! YOU LOSE!!!!!
