Go Back   HondaCivicForum.com > Your Ride > Nitrous, Super Chargers, & Turbos
Reply
Old 02-27-2008, 07:54 PM
gdl13 gdl13 is offline
Default greddy turbo kit for d16
I'm trying to get a greddy turbo kit for a d16 civic, anybody would recomend this type of turbo kit , or anything better without going to expensive
__________________
ismael munoz
Sponsored Links
Old 02-27-2008, 10:51 PM
gsumano gsumano is offline
Default RE: greddy turbo kit for d16
It's a good kit, however I highly recommend that you ditch the emanage and get a better fuel management like a chip ecu. Also, buy an intercooler.
Usually you get an used one with an intercooler for about 900-1,200 on turbod16, honda tech classifields or craigslist
__________________
Turbo d16y8
gt28r @ 7psi
Old 02-28-2008, 06:57 PM
ok, thanks bro. I'll try and do some more research.
__________________
ismael munoz
Old 02-28-2008, 07:49 PM
inthezone inthezone is offline
At first I wanted to turbo my D16, but was also looking ahead and other engine mods like pistons/rods/ported and polished head. That's a lot of money. And then I found out more about an engine swap, mainly the B16A2. Basically an easy swap, no special installation or extras needed. And with bolt ons and a few other extras, I could achieve my 200hp goal without going turbo. Of course I could add one later, but I'd rather have a more powerful engine with 100k less miles and have more support if I wanted to do anything to it. Also the internals are stronger so upgrading rods/pistons isn't really necessary if you wanted to boost.
__________________
'00 Ex Coupe - Stick, 17" Silver ADR Battle Exe Rims, Nitto NeoGen Tires, Secret Weapon R Intake
Next upgrades: B16A2 conversion, ACT Flywheel/Clutch, Greddy SP2 Exhaust/Header/Timing Belt, Megan Strut Bars, High-flow Cat
Old 02-28-2008, 09:29 PM
Quote:
ORIGINAL: inthezone
That really depends how much hp your are making, I wouldn't go over 250whp on b16 on stock internals just like I won't go over 210whp on a d16 stock internals. The d16 is really good platform to boost because if it blows, they are not that expensive to replace and they have lot's of potential.
__________________
Turbo d16y8
gt28r @ 7psi
Old 02-28-2008, 10:40 PM
mybrokenblinker mybrokenblinker is offline
good luck getting over 200 whp out of a b16a2
__________________
ROTOZEY19111 (2:40:30 PM): I bought a bigass can of seafoam TRANNY treatment
ROTOZEY19111 (2:40:51 PM): and put that in my crankcase
Old 02-29-2008, 12:48 PM
Quote:
ORIGINAL: mybrokenblinker
I/H/E/upgrade throttle body, high flot cat, ported head, yeah I'm sure you can get 200 whp.
__________________
Old 02-29-2008, 01:21 PM
Quote:
ORIGINAL: inthezone
The b16 has about 140whp, it's going to be tough and expensive to get 200whp with the mods you mention. Going that route, you will end up paying more than what it cost to get a d16 in the low 300whp[&:]
turbo setup~ 1,200
Piston and rods ~500
Good 300 whp tune ~500
vs.
B16 ~ last I remember a decentlow milage was around 2,500 (not including the motor mounts and axles)
Headers~ about 200
intake~ 100
tune~500
plus the port polish
In the end it would be more expensive than just boosting the d16. Yes the b16 has more pontential than a d16 but for a daily driver more than 300whp is useless on the street.
__________________
Turbo d16y8
gt28r @ 7psi
Old 02-29-2008, 03:37 PM
Quote:
ORIGINAL: inthezone
If you think that will get you to 200whp, i feel sorry for you when you get it dyno'd and you fall 30-40 hp short of your goal.
__________________
Old 02-29-2008, 04:27 PM
wouldn't a port and polish alone help open things up, maybe 30 or so hp. It puts out like 140 or 150 whp right?
to end argument, just boost the b16 and upgrade the rest if you want lol
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
