RE: d16y8 to jdm d15b swap (power loss at high rpm)
hello, well first of all. i have the same motor but opposite problem. i no power at lower rpm before vtec.. but when vtec hits.. its very good power.. and i know why this is happening.
well, for you situation. you should use the dual selenoid because one activites vtec at low rpm and another at high rpm. the only thing why your is not working is because. if you have the p2p ecu, the original ex ecu.. it will not activite the one vtec.. so you will either have one vtec either at low or high rpm...
The choices you have know is.. find the jdm 3 stage vtec and use the dual selenoid.. which is hard to find..
, you can also hook up the dual selenoid and connect the high rpm vtec to the ecu and buy a vtec controller to activiate the low rpm vtec to kick in.
or lastly.. you can use the replace the head to the y8 which is only 2 stage
and for me.. i am going to swap head to a y8 head.. havent done it yet but will soon.. i'll let you know how it goes ..
