head limits
Login | |
head limits - 3/1/2008 8:55:40 AM
bcivic
Ive been considering doing a turbo kit for a while now and I have finely decided to go through with it this summer. Now I am also considering doing a bit of an engine build JE pistons and rings and forged rods since I will be putting on a new head studs to prevent head lift. My initial goal was 250whp, I heard stock b16a s can produce 350whp with a very good tune. But with a somewhat built bottom end the said pistons rods rings I am wondering what kind of power is possible. Basically what is the limit of the stock sleeves and stock valvetrain how much horsepower can they take. I will be tuning with Hondata with 440 or 550 cc injectors and walbro 255lph fuel pump. t3/t4 turbo is what I will be using I think and does anyone know about coolant lines for that turbo does it have coolant lines?
_____________________________
1997 Honda civic dx engine swap b16a dohc vtec stage 3 clutch fidanza flywheel k&n intake dc sports 4-1 header high flow cat cat back lowering springs/ strut tower bar hasport motor mounts turbo coming soon hopefully
RE: head limits - 3/1/2008 5:10:19 PM
MY99SI
a friend of mine put down 424 whp on 23 psi on 10* of timing. on 93 pump stock b16 head simple piston and rod motor on stock sleeves nothing too crazy stock bore and stroke with GSR cams here's a link to the dyno video that i made of the car http://videos.streetfire.net/video/8915170a-576c-4daf-aac7-99c80124c072.htm as for coolant lines.. each turbo is different. you can get some with wet and dry versions. wet means it uses coolant and oil.. dry only uses oil.
http://limaracing.myfastforum.org
RE: head limits - 3/2/2008 2:51:34 PM
bcivic
Hey thanks for the reply man. If I decide to spend alot more money than I initially planned, I may end up with a similiar engine build.
RE: head limits - 3/2/2008 7:30:44 PM
SovXietday
Joined: 6/29/2006 From: Harleysville, PA Status: offline
Stock B16 head will move enough air for 700-800whp. Now, of course, that does not mean that you will not benefit from a PnP, but IMO if you aren't going for SERIOUS power don't bother.
Champ White 1996 Civic Hatchback - 57trim SOHC Black 1998 Z28 Camaro - LS1 M6
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Civic Prices
Honda Civic
Civic Si Concept
Advertising Info
Contact Us |
Advertising |
Automotive Resources |
Honda Civic Links |
Archive |
About |
Legal |
Privacy Policy |
© Honda Civic Forum
