Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
4-speed to 5-speed swap
  Printable Version
Honda Civic Forum >> Your Ride >> Transmission & Differential >> 4-speed to 5-speed swap Page: [1]
Login
Message << Older Topic   Newer Topic >>
4-speed to 5-speed swap - 3/1/2008 5:04:33 PM
spauldingscivic
Status: offline
Hello, I have a '90 civic hatch that came with a 4speed manual tranny. I plan on swapping to a 5 speed. Is this swap as easy as unbolting the shift rod, and tranny, or I am going to run into complications with the shifter ?. I am not understanding how the stock shifter is going to go from not having 5th gear to suddenly having it. Please help.
Post #: 1
RE: 4-speed to 5-speed swap - 3/2/2008 12:13:00 AM
Hailchristian
Status: offline
Hailchristian's photo gallery
its as easy as it sounds...
as long as you stay away from the 88 transmission your fine. the 88 has a differnt internal spline count and you will have to get a new clutch set up. But if you go with a 89, 90, or 91 you will be fine. The shift linkage lines up just fine and works just fine..
ill try to explain it.....so the shift linkage has two different ways it moves the transmission. It has a push/pull and it has a spin. The 1st, 3rd and 5th are all pull and 2nd, 4th and reverse are all push. So you when you put the car in first gear it pulls a lever on the transmission towards it.
THe other axes it has is left and right. 3rd and 4th have that same transmission lever perfectly strait. When you slide the shifter left and right it spins that lever and thats what makes it choose between the pulls/and pushes...
all the 5th gear adds is it adds a pull to the same side the reverse is on...
if you have some one arround have them switch through gears (with the car off) and then watch how the shift linkage looks under the car. im sure you will completely understand it.
good luck with the swap...
_____________________________
DOHC ZC (dead) SOHC ZC FTW!• K&N CAI filter • 90 Integra LS rear disc conversion
(in reply to spauldingscivic)
Post #: 2
RE: 4-speed to 5-speed swap - 3/17/2008 8:12:10 PM
spauldingscivic
Status: offline
Thanks for your help. I didn't think it would be that easy.
(in reply to Hailchristian)
Post #: 3
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Honda Civic >> Your Ride >> Transmission & Differential
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414248
remmy11161
fiirkan10517
mill$civic8471
marty8273
mxs8006
fliphkd7207714
nail i3unny7705
sacicons7675
addiction2ba7375
New Vendors
K&N Engineering, Inc.
