Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 03-02-2008, 06:34 AM
elsst3 elsst3 is offline
My Garage
Default 02 Civic man shifting issue
I have a 2002 ex manual.
The car sat for 3 or 4 days in the peak of winter. I got into the car and it seemed very stiff to shift. I changed the tranny fluid. smoother to shift but still verystiff. There is no grinding and it does not pop out of gear. I checked the clutch fluid and it was fine too.
It is not consistant and does not happen all of the time. It has good days and bad. It does not happen in all gears all the time. It happens both up and down shifting. It does not grind but it squeezs going into the gears when it is stiff. It is a clear squeeking noise not grinding. If I put it in nutral and shift through the stiff gears they seem to loosen up. The more I shift the better it gets. Also, if it seems to be stiff, i will rattle the gear shift in neutral before moving it into gear and it goes in super smooth. It seems that moving it around in neutral clears the path to get it into gear.
It was suggested to check the bushing in the shifter assembly. Apparently this was easier to do in older modles then the new ones. You have to replace the entire assembly now, not just the bushing. That's what honda told me anyway. They also suggested cheking the cables. I have done lots of searches and can not find any DIY for checking or replacing these cables. i don't know how to get to the cables. It was also suggested that i disconnect the cabels from the assembily. this will help determine where the problem resides.
Any info would be helpful!
thanks!
__________________
erin smith
Sponsored Links
Old 11-07-2008, 05:06 PM
mountain_man's Avatar
mountain_man mountain_man is offline
My Garage
I drive a 2001 LX manual with 250,000 miles. I have the exact same problem. Does anyone know what the problem is, and how to fix it?
Thanks
Old 11-07-2008, 05:33 PM
RonJ RonJ is offline
HCF Humble Servant
My Garage
Send a message via AIM to RonJ
1) Drain your transmission fluid and replace with genuine Honda MTF.
2) There are several places in the shift mechanism that require lubrication. Try regreasing them:
__________________
DIY 92-00 Civic Check Engine Light (CEL) http://www.honda-tech.com/showthread.php?t=878010
Manuals http://hondatech.info/downloads/Auto/Manuals/Civic/
97 Civic DX sedan, D16Y7 MT --- 00 Civic EX coupe, D16Y8 AT
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
