Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 03-03-2008, 10:18 AM
watkinsgolden watkinsgolden is offline
My Garage
Default Torque Converter Code
Hi everyone, new member. Looks like there's some knowledgeable folks here, I hope you can help.
2001 Civic EX Coupe A/T, I just started getting a P0740 code, which points to the lock up control being the issue. I did some research & found a HOnda note saying don't replace the tranny til you've replaced the Torque Converter Clutch Solenoid Valve and the A/T Clutch Pressure Control Valves A and B. The problem is, where are they? My Haynes book says if you're removing the A/T, unconnect the above solenoid & valves, but gives no notes as to where they are. Am I better off having my mechanic do it, or is it something I can get to myself without too much trouble.
Basic mechanical skills, I just changed a timing belt on my Pathfinder. But don't have much experience with transmissions.
Thanks for any help.
Sponsored Links
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
