Go Back   HondaCivicForum.com > Your Ride > Nitrous, Super Chargers, & Turbos
Reply
Old 03-04-2008, 08:12 PM
arust45 arust45 is offline
My Garage
Default Reliable for 350whp?
Just swapped out my 75 mm vitaras for .02" over. I was told that these pistons in conjunction with my h-beams will hold 350whp. Also have ARP's, oem gasket, block guarded, and y8 oil pump from the dealership. Been reading about the shortcomings of the y8 pump, does it need to be ported or shimmedfor a reliable 350whp turbocharged d16y8? Also what power differences are noticeable with the slightly larger bore size?
__________________
97 Civic Sedan
D16y8, Vitara/Eagle
243wtq@18psi
Sponsored Links
Old 03-04-2008, 08:20 PM
riceburner700's Avatar
riceburner700 riceburner700 is offline
My Garage
Send a message via AIM to riceburner700
Default RE: Reliable for 350whp?
always shim a dseries pump. they suck at oiling, yes the vitaras/eagles will be plenty good for 350
__________________
cylinder head guru!
Non Vtec power
Old 03-05-2008, 10:08 AM
FlipHKD720's Avatar
FlipHKD720 FlipHKD720 is offline
My Garage
Send a message via AIM to FlipHKD720
Sovxietday has an OEM oil pump that has been ported and he's running more than 350hp i beleive. So that could be an option for your oil pump.
He also has Vitaras, Eagle rods and ARP headstuds, i say you'll be good with your setup.
__________________
Old 03-05-2008, 07:59 PM
My Garage
I trust his judgement, but I wonder how long he has been running that setup. I don't trust those cast vitaras when the life of my engine is at stake. I'm only planning around 260whp for my high boost setting and keeping the low between 225 and 235.Not lookin to make perty numbers at the track, just want a fun project without having to get new axles and transmission work done...not yet at least. At least I have the 1000 mile break in period to think it over. Any opinions on megasquirt?
__________________
97 Civic Sedan
D16y8, Vitara/Eagle
243wtq@18psi
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
