1g dsm smic in EG
Login | |
1g dsm smic in EG - 3/5/2008 10:47:56 PM
s0ulj3r
How easy is the mounting for this beast?? And any available piping kits?
RE: 1g dsm smic in EG - 3/5/2008 11:41:50 PM
RCJr9186
Joined: 4/3/2007 From: Summerville, SC Status: offline
i wouldn't call it a beast by any means. honestly if i was going smic... i'd go w/ the Supra SMIC, it will flow a lot better and support 400hp no problem.
_____________________________
93 Del Sol S - Greddy EVO2 Catback B18c JDM GSR Fidanza Prolite 6.98lb Aluminum flywheel. F1 Racing Stage 2 Clutch Lightweight pulleys
RE: 1g dsm smic in EG - 3/5/2008 11:50:17 PM
FlipHKD720
you usually have to get a bit creative with the piping, either hack sawing/cutting, and then sometimes welding it, other times (easier a bit, can do this just with sockets/wrenches/screwdrivers) just getting a nice get of couplers and T-bolts (better than those dinky little clamps) will do. any reason your going SMIC over FMIC? You just get your hands on one?
RE: 1g dsm smic in EG - 3/6/2008 12:09:58 AM
s0ulj3r
quote:
ORIGINAL: FlipHKD720 you usually have to get a bit creative with the piping, either hack sawing/cutting, and then sometimes welding it, other times (easier a bit, can do this just with sockets/wrenches/screwdrivers) just getting a nice get of couplers and T-bolts (better than those dinky little clamps) will do. any reason your going SMIC over FMIC? You just get your hands on one? pretty much; just goin on my DD civic.. no need to get all fancy and FM it, i can get a SMIC for like 25 bucks.. i'm just worried about the piping, and how hard it will be.
RE: 1g dsm smic in EG - 3/6/2008 12:23:11 AM
FlipHKD720
you can buy custom piping kits off ebay for like $100, i found one with t-bolts included as well. Yea $25 is cheap, btu IMO i dont think FMIC is too fancy. Its a pretty basic setup, especially becasue of the way you usally run charge piping in 5th and 6th gen Civics.
RE: 1g dsm smic in EG - 3/6/2008 8:24:21 AM
RCJr9186
it also depends on what kind of turbo you are going to e running. if you are planning on running a 16g or larger, i'd suggest going with a smaller fmic rather than a dsm smic. the smic will start heat soaking BADDD anything over 250whp.
