Ok, Time for a fuel pump for my turbo setup, Need advice
Login | |
Ok, Time for a fuel pump for my turbo setup, Need advice - 3/9/2008 5:30:58 AM
dave_57204
Joined: 9/16/2007 From: Burlington, NJ Status: offline
Allright, I'm getting close to completing to everything I need for my setup, I wanna upgrade my fuel pump. What do you guys reccomend? Also internal or external?
_____________________________
Dont let them block what drives you
RE: Ok, Time for a fuel pump for my turbo setup, Need a... - 3/9/2008 11:01:54 AM
RCJr9186
Joined: 4/3/2007 From: Summerville, SC Status: offline
what kinda power are you going to be running? anything under 300 and i'd go w/ the walbro190 but 300-500 and a 255 will do you just fine.
93 Del Sol S - Greddy EVO2 Catback B18c JDM GSR Fidanza Prolite 6.98lb Aluminum flywheel. F1 Racing Stage 2 Clutch Lightweight pulleys
RE: Ok, Time for a fuel pump for my turbo setup, Need a... - 3/10/2008 8:36:15 AM
dave_57204
I'm gonna be running on stock internals for now. So 175-200. Should I just get the 255 since I will more then likely building up the engine for more boost soon enough. Also I've seen the internal pumps and external ones, I'm assuming I need the in tank one?
RE: Ok, Time for a fuel pump for my turbo setup, Need a... - 3/10/2008 9:07:45 AM
FlipHKD720
Walboro makes a good fuel pump from what i hear.
RE: Ok, Time for a fuel pump for my turbo setup, Need a... - 3/10/2008 1:21:47 PM
Overurhead360
I have also heard that the walbro 255 is a good intank pump to use.
Silly ricers, wings are for planes!
RE: Ok, Time for a fuel pump for my turbo setup, Need a... - 3/10/2008 5:44:37 PM
SovXietday
Joined: 6/29/2006 From: Harleysville, PA Status: offline
Walbro 255LHP. Easy as hell to put in, quiet, and will be good to 600whp.
Champ White 1996 Civic Hatchback - 57trim SOHC Black 1998 Z28 Camaro - LS1 M6
RE: Ok, Time for a fuel pump for my turbo setup, Need a... - 3/10/2008 11:43:45 PM
dave_57204
Allrighty, Thanks. Any of you guys have the chiltons guide handy for it?
RE: Ok, Time for a fuel pump for my turbo setup, Need a... - 3/11/2008 3:22:21 PM
Mr Mobsta Man
Joined: 6/29/2006 From: West Virginia Status: offline
Walbro 255lph FTW. As for the install manual, what year/model car do you have?
quote:
ORIGINAL: Vilex Honestly, if you would want to buy a modded civic with all the work done for you. I pity you, thats no Honda Enthusiast.
RE: Ok, Time for a fuel pump for my turbo setup, Need a... - 3/11/2008 7:15:18 PM
dave_57204
Oh yeah, sorry. 99 Honda civic LX 4 door d16y7
RE: Ok, Time for a fuel pump for my turbo setup, Need a... - 3/12/2008 4:50:09 PM
SovXietday
Take out the bottom of the back seat. Unbolt the fuel pump cover, unplug all the plugs, pull the fuel pump out. Swap and reinstall. It's really really easy.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Civic Prices
Honda Civic
Civic Si Concept
Advertising Info
Contact Us |
Advertising |
Automotive Resources |
Honda Civic Links |
Archive |
About |
Legal |
Privacy Policy |
© Honda Civic Forum
