Internal Upgrade d16z6 For 7lbs Boost
Login | |
Internal Upgrade d16z6 For 7lbs Boost - 3/9/2008 8:06:21 PM
that deal
Hey all, I want to run 7lbs of boost via turbo charger... I've heard that all i need internaly is a rod upgrade...? <True? Also, I have a stage one cam, adjustable fuel pressure reg and im wondering if i should advance or retard the timing of the cam and what fuel pressure i should run for optimal performance... Thanks for the help
RE: Internal Upgrade d16z6 For 7lbs Boost - 3/9/2008 8:23:59 PM
FlipHKD720
Eagle Rods, Vitara pistons, ARP headstuds, OEM or Cometic Headgasket, sleeves aren't totally necesarry unless you're doing a pretty intense build. On 7 psi on a smaller turbo, a stock d16z6 has been known to hold up find for a while if properly tuned and the whole process was done right the first time (quality parts, knowledge, nice dyno tune, etc.). I think you can retard timing when tuning your car, which is necesarry when you're turbocharged.
_____________________________
RE: Internal Upgrade d16z6 For 7lbs Boost - 3/9/2008 9:10:10 PM
that deal
ALL those mods are absolutely needed?
RE: Internal Upgrade d16z6 For 7lbs Boost - 3/9/2008 9:30:45 PM
FlipHKD720
naw dude like i said a stock d16z6 can make it if you keep HP levels low and have a super good OBD1 chip/tune, but the lower compression pistons, stronger rods, nice headgasket, and some good strong headstuds you're engine is much more reliable and also more prepared for alot higher boost numbers. What turbo are you running? That matters more than PSI actaully, because 7 lbs of boost is a completely different think from a small t25 then on a huge Garrett diesel turbo or something. Leaving a t25 internally gated will give you pretty okay numbers on a DD and it's internally gated at a low PSI already. EDIT: and getting a compression test on your engine lets you know what kinda shape it's in and if can handle boost in the first place.
< Message edited by FlipHKD720 -- 3/9/2008 9:36:17 PM >
RE: Internal Upgrade d16z6 For 7lbs Boost - 3/10/2008 8:24:01 PM
arust45
Its a gamble. I suggest, at the minimum, new headgasket and arp headstuds. If you are putting enough power to throw a rod, you'll need stronger pistons as well. Many people swear that the rods will go first, but i've also talked to many people who have had turboed civics where the pistons went first. When I turboed my d16y8 (with 115k miles) with a t3/t4 on 7lbs all hell broke loose. First I stripped my clutch and blew my headgasket due to headlift because I was using stock headstuds. Blown headgasket->Overheating->hole in radiator->glazing on cylinder walls->metal shavings in my vtec solenoid from my rods and rod bearings. IMO all you absolutely need is a clutch that can handle the new power you'll be making, but if you want your engine to be reliable follow flip's advice. Also, do you mean retard the ignition timing?
RE: Internal Upgrade d16z6 For 7lbs Boost - 3/11/2008 3:27:12 PM
Mr Mobsta Man
Pistons go first due to lack of good tuning methods (i.e. fmu, piggyback) or even just a bad tuner himself on a good management system. Clutch is going to go out no matter what, they just were not ment to handle the torque of a turbocharged engine.
quote:
ORIGINAL: Vilex Honestly, if you would want to buy a modded civic with all the work done for you. I pity you, thats no Honda Enthusiast.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Civic Prices
Honda Civic
Civic Si Concept
Advertising Info
Contact Us |
Advertising |
Automotive Resources |
Honda Civic Links |
Archive |
About |
Legal |
Privacy Policy |
© Honda Civic Forum
