Go Back   HondaCivicForum.com > Your Ride > Transmission & Differential
Reply
Old 03-12-2008, 11:13 PM
bdouglas bdouglas is offline
Default Should I be worried?
I bought this 95 EX A/T coupe that seems to be in good shape. After breaking off the O2 sensor in the stock manifold, I figured I'd just add a stainless exhaust since they're dirt cheap now. I installed a header, hi-flow cat, and N1 catback on it. I've also gotten a SRI to install (see some other post).
The car seems astoundingly fast to me. If I step on the gas, it takes off briskly, to say the least. I haven't yet done a transmission fluid change, but its on the top of the list. I try to baby the car, but due to its nature, it seems like you have to rev it up pretty good to get anywhere.
First of all, should I be concerned that the A/T will die a horrible death after these mods? I don't want to be replacing the transmission ever, if possible.
Second, how does the AMSOIL synthetic ATF work in Hondas? Does it shift right? Slip? If it performs reasonably well, then I would definately consider using it.
Finally, just how carefull am I going to have to be? I tend to just plod along usually, but once in a while you have to step on it. I've seen some automatics last for very long times under hard usage. I just want a feel for how robust this transmission is in the 95 with the VTEC. Thanks.
__________________
Got guns?
Sponsored Links
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
