Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
Please help with my tranny problems
  Printable Version
Honda Civic Forum >> Your Ride >> Transmission & Differential >> Please help with my tranny problems Page: [1]
Login
Message << Older Topic   Newer Topic >>
Please help with my tranny problems - 3/15/2008 9:09:06 AM
Eddieinthecity
Status: offline
 I have a 97 Civic HX. My civic's idle is perfectly fine when in neutral, but when I drive, I feel a constant light thrusting. When I stop at a light the thrusting gets bad. The idle goes from 1200 to 0  back and forth, if I hold the brake too weak I leap forward. Now Im used to putting it in neutral at red lights. On some rare occasions, the idle is fine and nothing happens throughout a day of driving. I don't get it. Has anyone else had this problem?
Post #: 1
RE: Please help with my tranny problems - 3/15/2008 9:44:17 AM
addiction2bass
Status: online
addiction2bass's photo gallery
is this a automatic?
sounds really odd....
gotta be some small sensor or something messing up, do you have the CEL  light on the dash?
_____________________________
(in reply to Eddieinthecity)
Post #: 2
RE: Please help with my tranny problems - 3/15/2008 10:24:45 AM
Aaron_EX
Status: offline
My first suggestion would be to check all sensors, be sure that they are clean. Use some throttle body cleaner make sure your TB is clean
also make sure there is nothing around the throttle body that could be opening it by pressing on the part that the gas peddle goes to (no idea what its called)
its sounds more like the something with the TB than the trasmission. but i may be wrong.
also unplug the IAVC and see what it idles at.
< Message edited by Aaron_EX -- 3/15/2008 10:35:02 AM >
In my four door, you know what the means, i can fit more hoes.
(in reply to addiction2bass)
Post #: 3
RE: Please help with my tranny problems - 3/21/2008 8:19:58 AM
Eddieinthecity
Status: offline
Ok got the car back from mechanic. Cleaned the throttle. Check engine light was on so long before i had it that the bulb burnt out. I am told that the egr valve is clogged and the car is running lean. Im paying almost 100 bucks an hour of labor for them to look for problems, its getting ridiculous.
They are telling me that in order to fix the surging idle, I would have to replace the transmission to cancel that out as a factor. Would a transmission make the idle do something like that?
< Message edited by Eddieinthecity -- 3/21/2008 8:31:08 AM >
(in reply to Aaron_EX)
Post #: 4
RE: Please help with my tranny problems - 3/21/2008 11:47:02 AM
addiction2bass
Status: online
well i dont think the tranny would make the engine surge.
i would get the engine  trouble codes and fix those first. and see what they does. other than that i would deal with it if its not that bad....
replacing a automatic tranny aint cheap!
it might not even be a problem infact.... could just be the normal pull on the tranny, lets face it if ya let off the brake its gonna have enough pressure to make the car want to go forwards.... it could just be your motor is running crappy from the bad sensors that need to be replaced that its puting more of a strain on the driveline....
just fix that CEL light bulb and get the codes and fix those error codes. hell the car already needs them obviously! then if the problem is still there  then worry about it more.
Post #: 5
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Honda Civic >> Your Ride >> Transmission & Differential
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414255
remmy11161
fiirkan10534
mill$civic8473
marty8273
mxs8006
fliphkd7207731
nail i3unny7705
sacicons7688
addiction2ba7455
New Vendors
K&N Engineering, Inc.
