RE: Ball Joints problem
if the tip is sticking through the nut, you can sometimes use a 4" C-clamp to clamp the tip of the bolt and clamp it down so it wont move, then use an open-ended wrench to turn the nut. if you cant do that, then sometimes you can just press the ball joint into the mounting hole hard enough to seat it enough to turn it.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
