NEED HELP
Login | |
NEED HELP - 3/19/2008 12:33:08 PM
ballincivic94
Im trying to turbo my honda civic (d16z6) but i dont know wether to buy a kit or build one around a Garret turbo. Also does the GReddy turbo kit allow you to keep your a/c. If you can tell me a good size turbo to keep stock internals and run at 7psi along with a manifold that allows me to keep my a/c please help me.
RE: NEED HELP - 3/19/2008 4:14:40 PM
Mr Mobsta Man
Joined: 6/29/2006 From: West Virginia Status: offline
The search button doesn't bite, I promise. Gah, okay. I'm in a good mood so I will tell you anyway even though this has been discussed literally hundreds of times. Building is cheaper but requires some knowledge. (this would require you to search more btw) Greddy kits allow you to keep a/c. Don't base your goals on a psi, go for a power level. 7psi on a small turbo will not make nearly as much hp as 7psi on a bigger turbocharger. t25 turbo would be a good choice for a stock internal setup. Log manifolds are a good way to go to keep a/c and are good up to 300hp.
< Message edited by Mr Mobsta Man -- 3/19/2008 4:24:22 PM >
_____________________________
quote:
ORIGINAL: Vilex Honestly, if you would want to buy a modded civic with all the work done for you. I pity you, thats no Honda Enthusiast.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Civic Prices
Honda Civic
Civic Si Concept
Advertising Info
Contact Us |
Advertising |
Automotive Resources |
Honda Civic Links |
Archive |
About |
Legal |
Privacy Policy |
© Honda Civic Forum
