Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
Good flasher problem write up - LED turn signals, etc
  Printable Version
Honda Civic Forum >> Your Ride >> Audio/Visual Electronics >> Good flasher problem write up - LED turn signals, etc Page: [1]
Login
Message << Older Topic   Newer Topic >>
Good flasher problem write up - LED turn signals, etc - 3/23/2008 7:56:20 PM
Stumasters
Status: offline
Stumasters's photo gallery
Well I am always in the market for new information, and recently someone sent me to the Bugman, a sportbike rider that has done some interesting mods to his bike over time.
Now I think his bike is kinda tacky with all the stuff, but he did manage to create a website with some good information.
This link provides some information on how to correct LED lighting "flash to fast" problems for those of you investigating and installing LED turn signals in your older civics.  He goes into detail on a few ways to fix the problem, although you will have to adapt his work to your car.
In short, flash to fast problems are caused by mechanical flashers that operate on the basis of current draw.  Because normal bulbs operate at a higher wattage and use more resistance then LED's, some flashers do not function correctly becasue of the lack of current draw on the circuit.
Bugman shows us how to repair the problem by replacing your flasher with a new upgraded flasher, or the resistor trick, which I use on my bike also.  By placing a certain resistor in parallel of the circuit on each side where the new LED signals will be installed, you "Trick" the circuit into thinking that the normal bulbs are still installed, and therefore the signal flashes at the correct rate, around once per second.
Check it out, might find some useful stuff on his site, i did.
http://www.bugmanweb.com/gsxr/gsxrindex.html
_____________________________
American cars
Thanks to Windcalmer for the sig!
http://www.geocities.com/black97civic
Post #: 1
RE: Good flasher problem write up - LED turn signals, etc - 3/24/2008 10:40:07 PM
klownkiller
Status: offline
suhweeet
thanks bro
my buddy is having this problem....
i send this page his way.
(in reply to Stumasters)
Post #: 2
RE: Good flasher problem write up - LED turn signals, etc - 3/26/2008 6:28:39 AM
Stumasters
Status: offline
There are alot of fixes for similar problems, but ultimantely, I think the resistor trick will fix a majority of them, the trick is finding the correct resistor.
I am thinking about investing in some LED signals myself, I am really hoping this will correct any issues I run into.
In order to use LED's, you have to get some understanding on how they operate, when compared with the standard filament bulb.  It's crazy how much power they "don't" use.  In 10 years, everything will be LED.
American cars
(in reply to klownkiller)
Post #: 3
RE: Good flasher problem write up - LED turn signals, etc - 4/25/2008 8:40:12 AM
Stumasters
Status: offline
http://superlumination.com/images/leds/installation.jpg
Here's a good link to the write-up I was given.
This is one option of correcting the "fast flash" problem that occurs when you swap your normal filament bulbs out for LED tower bulbs, or otherwise LED bulbs.
You can also purchase a new mechanical flasher from any autoparts store and swap it out with the factory one, to correct the problem.  Mechanical flashers flash at a standard rate, no matter what load is present on the circuit, so you can add all the LED bulbs you want, and not have a fast flash issue.
Word.
American cars
Post #: 4
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Honda Civic >> Your Ride >> Audio/Visual Electronics
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414259
remmy11165
fiirkan10543
mill$civic8473
marty8273
mxs8006
fliphkd7207739
nail i3unny7705
sacicons7699
addiction2ba7491
New Vendors
K&N Engineering, Inc.
