Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
for my turbo project, i know i need these, but do i need these?
  Printable Version
Honda Civic >> Your Ride >> Nitrous, Super Chargers, & Turbos >> for my turbo project, i know i need these, but do i need these? Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
for my turbo project, i know i need these, but do i nee... - 3/29/2008 10:02:12 AM
00IntegraLS
Status: offline
alright guys I'm oh so close to having a turbo in my car. i have a 2000 integra ls. this IS MY DAILY DRIVER and i plan on keeping it @ 7 psi
heres my turbo kit:
drag exhaust mani
turbonetics t3/t4 turbo
tial 38mm wastegate
blitz blow off valve
front mount intercooler
drag boost dependent FMU fuel regulator
MAP sensor bypass valve assembly w/blox MAP bypass
drag high pressure/high volume inline fuel pump
all the piping, etc.
I know I need/plan to get
act clutch
arp headstuds
new head gasket
new timing belt
ngk spark plugs
gauges
turbo timer
new camshafts
hondata s300 w/dyno tune
should I get....
boost controler
bigger injectors
cooler radiator
walbro fuel pump (or no since the kit comes with the inline fuel pump)
springs & retainers
i wont need low compression pistons since i dont have plans on going much above 7 psi right?
anything else i didnt think of?
Post #: 1
RE: for my turbo project, i know i need these, but do i... - 3/29/2008 1:47:04 PM
importcivicus
Status: offline
importcivicus's photo gallery
as far as i cna see you are on the right track but I would suggest that you get this stuff also
bigger injectors-if it doesnt come in the kit
cooler radiator-yes to keep ur engine cooler seeing there is going to be so much heat under hood with the turbo
walbro fuel pump-not really nessiceray but its a plus
springs & retainers-to help out with the cam if u put them on. if u go aftermarket cams you will need them.
what kit did u get or was it a piece together kit.
_____________________________
Turbo K20A3 built head and long laundry list to go with that
working on getting a K24 and boosted
(in reply to 00IntegraLS)
Post #: 2
RE: for my turbo project, i know i need these, but do i... - 3/29/2008 1:55:31 PM
00IntegraLS
Status: offline
kit is a rev hard generation III kit.  it is $3,000 and you can get the clutch from them too for $350, rc 310cc injectors for $310.  are those the right size injectors?
also, should I get a hood with a hood scoop and some vented fenders too to help with cooling?
< Message edited by 00IntegraLS -- 3/29/2008 2:04:13 PM >
(in reply to importcivicus)
Post #: 3
RE: for my turbo project, i know i need these, but do i... - 3/29/2008 4:28:06 PM
importcivicus
Status: offline
is this the info for ur kit our along these lines:
NEW! Stage: 2 Use: Street/Track Part #: RHSTGII MSRP: $3,599.00 (New Pricing) This kit will be Pending CARB legality Boost Level: 7 PSI Injector Size: Stock Horsepower/Torque: +120 / 285 ft/lbs
  • Rev Hard Cast Iron Manifold
  • Rev Hard T3/T04E Hybrid Turbo(eff. to 450hp)
  • Rev Hard Intercooler (28x6.5x3)
  • Tial Wastegate (7 PSI)
  • Rev Hard Blow-Off Valve
  • 2.25" Mandrel Bent Piping
  • 2.5" Downpipe
  • Billet Map Diffuser (Check Valve)
  • High Volume Fuel Pump
  • Silicone Hoses and Clamps
  • Steel Braided -3 Oil Line
  • Oil Return Line
  • High Pressure Fuel Line
  • High Pressure Silicone Hoses
  • Necessary Vacuum Lines
  • Rev Hard FMU
  • Necessary Vacuum Tee's
Optional Upgrades
  • 2.5" Aluminum Upper Charge Pipe for 94-01 Integras / 92-00 Civics
  • Ball Bearing Turbo Upgrade
  • Tubular Manifold Upgrade
Available Applications 00+ Honda S2000 Scion XB and TC Coming Soon! 02+ Lancer Evo 8 92-00 Civic (D Series Motors) 92-00 Civic Hybrid (B-Series H22 VTEC) 94-01 Integra (All) 97-01 Honda Prelude 88-91 Civic/CRX (D16/ZC) 88-91 Civic/CRX (B Series Motors) For all 88-91 Civic / CRX only - Requires removal of air conditioning, smaller radiator, cutting the subframe, and relocating or use of a smaller battery. 90-93 Integra (ALL) - Requires removal of air conditioning Please call us for custom applications.
cause this is the only thing really rev hard has for the b-serries motors.
Post #: 4
RE: for my turbo project, i know i need these, but do i... - 3/30/2008 6:19:47 PM
00IntegraLS
Status: offline
oh poop... i meant drag!  i was going to go with the rev hard before i found this one.. yea its a drag kit...   www.dragturbokits.com
Post #: 5
RE: for my turbo project, i know i need these, but do i... - 3/30/2008 8:25:04 PM
GReddy_Civic
Status: offline
GReddy_Civic's photo gallery
You might wanna get the injectors and fuel pump. I dont know much about drag kits butit cant hurt.  Oil lines? Dunno, seems like you should be doin more research instead of shoppin
Surf Wagon1994: might be getting a toy :D
Forty4U2BNVS: I've been known to toot a pipe or two
Post #: 6
RE: for my turbo project, i know i need these, but do i... - 3/31/2008 9:16:43 AM
00IntegraLS
Status: offline
oil lines? what are you even talking about?
(in reply to GReddy_Civic)
Post #: 7
RE: for my turbo project, i know i need these, but do i... - 3/31/2008 9:52:02 AM
GReddy_Civic
Status: offline
you gotta have a way to cool the turbo, whether it be oil or water, and im assuming the t3/t4 is oil.  You have to have a way to cycle the oil.  Otherwise youll ruin the turbo.  I suggest you do A LOT more research before you go and blow up your engine.  Or if you want, run it without oil lines...let me know how it goes  ::thumbup::
< Message edited by GReddy_Civic -- 3/31/2008 12:08:20 PM >
Post #: 8
RE: for my turbo project, i know i need these, but do i... - 3/31/2008 1:18:47 PM
gsumano
Status: offline
gsumano's photo gallery
quote:
ORIGINAL: 00IntegraLS
Turbo d16y8
gt28r @ 7psi
Post #: 9
RE: for my turbo project, i know i need these, but do i... - 3/31/2008 1:25:48 PM
GReddy_Civic
Status: offline
quote:
ORIGINAL: gsumano
Sigh... go talk to tony, he'll laugh in your face.  No oil, no problem!
(in reply to gsumano)
Post #: 10
Login OR Register now to post a reply to this forum topic.
Honda Civic Forum >> Your Ride >> Nitrous, Super Chargers, & Turbos
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414258
remmy11165
fiirkan10543
mill$civic8473
marty8273
mxs8006
fliphkd7207739
nail i3unny7705
sacicons7693
addiction2ba7482
New Vendors
K&N Engineering, Inc.
