RE: B16 SIR 1 OR B16 SIR 2
yeah, you'll need the wiring adapter, and its pretty pricey, youll also need a mount kit, and either a conversion kit for a cable clutch, or a hydrolic tranny. just go with the higher compression of the b16a2(SiRII) that will basically bolt into your car with factory honda/acura shift linkage and motor mounts. you can give Hasport a call @ 602.470.0065 , they were very helpful to me when i was doing my swap, even though i didnt end up buying anything from them.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
