Go Back   HondaCivicForum.com > Your Ride > Header, Intake, & Exhaust
Reply
Old 03-30-2008, 11:42 PM
z_dizzlemang z_dizzlemang is offline
My Garage
Default O2 Sensor removal????
i have a 94 civic with a D16, i have a new header on the way, and will be installing myself, is a O2 sensor tool needed, or will a wreanch work?
Sponsored Links
Old 03-30-2008, 11:44 PM
Hailchristian's Avatar
Hailchristian Hailchristian is offline
My Garage
Send a message via AIM to Hailchristian
Default RE: O2 Sensor removal????
you will need a pretty long socket...if you don't have one long enough....you will need the tool
or if you will be replacing it you could just break it off..that's what i did.
__________________
DOHC ZC (Waiting for rebuild) SOHC ZC FTW! K&N CAI filter 90 Integra LS rear disc conversion Working on Black interior
Old 03-31-2008, 01:58 AM
alecrust alecrust is offline
My Garage
I highly doubt you will need a specialised tool. Mine came out fine with just a spanner on my 98.
__________________
Old 04-03-2008, 10:55 AM
point break 92 point break 92 is offline
My Garage
Send a message via AIM to point break 92
play it safe and smart, get the special tool, it's 5 bucks it's just a socket you add on to your wrench. do it !!!!
__________________
[IMG][image/]
Old 04-03-2008, 11:01 AM
My Garage
I diasagree. It's a standard nut, and usually easily accessible. Only get the speacial tool if you are having trouble with just a spanner.
__________________
Old 04-03-2008, 11:23 AM
T3rry T3rry is offline
My Garage
the only thing with the "special tool" is it's a socket with a hole down the side to accomidate for the wires, use a wrench, or if you dont care about the sensor, snip the wire and use a normal deep socket.
__________________
04 LX EM2: http://www.cardomain.com/ride/3049153
Mods (done):
17" Tenzo-r GT6 Rims
RS-R Down springs
35% tint on 5 windows
Ebay projs w/ HID
Mods (coming):
OEM fogs, smoked
Smoked tails
full EX exhaust
SRI
Old 04-03-2008, 01:29 PM
FlipHKD720's Avatar
FlipHKD720 FlipHKD720 is offline
My Garage
Send a message via AIM to FlipHKD720
unclip the harness, use an open ended wrench and you'll be fine. Just dont use any lubricant to remove the sensor if its still working properly because the lubricant could damage the sensor.
__________________
Old 04-03-2008, 03:14 PM
importcivicus importcivicus is offline
My Garage
Send a message via Yahoo to importcivicus
Quote:
ORIGINAL: FlipHKD720
Follow flips advice. There is nothing wrong with it. This is the far best one to go with. The wrench you need should be a 21mm. Use the closed end first after disconnecting the wiring harness off first. Slip the wires through and on the nut then take off. Its that simple.
__________________
Turbo K20A3 built head and long laundry list to go with that
working on getting a K24 and boosted
Old 04-04-2008, 06:57 PM
koots koots is offline
My Garage
I took all of mine off with a wrench when i put my header on. It was fairly easy if there is nothing seized on it. don't let all the special tools fool you, they are not necessary but they do make things a little easier.
__________________
97 EX Sedan (Canadian)
-Low and Slow, Except in Corners
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
