Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
Clutch and flywheel
  Printable Version
Honda Civic Forum >> Your Ride >> Transmission & Differential >> Clutch and flywheel Page: [1] 2 3   next >   >>
Login
Message << Older Topic   Newer Topic >>
Clutch and flywheel - 4/1/2008 9:59:09 PM
EJ1Coupster64
Status: offline
EJ1Coupster64's photo gallery
i need some help, i upgraded my engine but didnt do anything to the flywheel and slapped on some crapy as stage one clutch. could anyone tell me whatflywheel and clutch setup to use for an enigine with roughly 280 - 315 hp. Thanks much appreciated
_____________________________
You take your pick the 195HP AE86 or the 285HP EJ1
Post #: 1
RE: Clutch and flywheel - 4/3/2008 11:29:11 AM
bcivic
Status: offline
How did you get 280 to 315 horsepower without a turbo and Dyno tune?  as far a clutch and flywheels go the flywheel only helps by dropping the rotating mass its the clutch that is rated with how much torque it can hold and that varies with different companies.  ACT has good clutches and flywheels you probably only need a stage 1 clutch  and if you want the lighter flywheel for a bit more horsepower and throttle response.
1997 Honda civic dx
engine swap b16a dohc vtec stage 3 clutch fidanza flywheel
k&n intake
dc sports 4-1 header
high flow cat
cat back
lowering springs/ strut tower bar
hasport motor mounts
turbo coming soon hopefully
(in reply to EJ1Coupster64)
Post #: 2
RE: Clutch and flywheel - 4/3/2008 1:41:10 PM
inthezoneac
Status: online
act clutch and act flywheels are good. They have different clutches for various setups.
(in reply to bcivic)
Post #: 3
RE: Clutch and flywheel - 4/3/2008 7:00:00 PM
EJ1Coupster64
Status: offline
i have had it on an engine dyno i havent put it on a chassis dyno yet and no its not turbo its just well modded i havent even driven it yet not until i get the driveline finished. i hate turbos by the way
Post #: 4
RE: Clutch and flywheel - 4/5/2008 7:38:01 AM
bcivic
Status: offline
What kind of engine do You have?
1997 Honda civic dx
k&n intake
high flow cat
cat back
Post #: 5
RE: Clutch and flywheel - 4/8/2008 9:44:55 PM
lawlersauce
Status: offline
Honda engine? 280-315 hp? No turbo? NO WAY
Post #: 6
RE: Clutch and flywheel - 4/9/2008 9:51:10 AM
EJ1Coupster64
Status: offline
B16A with Toda everything-Valvetrain, Cams and Cam gears, Metal headgasket (0.6mm) and even Toda's 1800cc Capacity up kit. C/R 11.5:1 I had one of my friends help me. We went to UTI, and yes it is possible just got to have everything setup perfect and unlimited budget. I have seen more power than that from a Honda motor.
< Message edited by EJ1Coupster64 -- 4/9/2008 10:00:06 AM >
(in reply to lawlersauce)
Post #: 7
RE: Clutch and flywheel - 4/17/2008 6:46:45 PM
sacicons
Status: offline
sacicons's photo gallery
280 fwhp? then an Exedy stage 1 should be enough. has a great pedal feel and engagement compared to the more aggressive ones. youre getting near its limits, but personally, i dont think the rough engagement is worth it for a higher rated one. and it pairs well with their 9.46# flywheel, esp on an NA motor. btw, whats the rest of the specs on that motor? which cams and what are you using for the intake manifold?
quote:
ORIGINAL: Forty04
I choose the rear ending
Post #: 8
RE: Clutch and flywheel - 4/18/2008 12:01:28 AM
gsumano
Status: offline
gsumano's photo gallery
quote:
ORIGINAL: sacicons
Maybe mine's defective, but my excedy stage 1 is starting to slip and it's only like 7 months old and i'm only making around 150 of torque
Turbo d16y8
gt28r @ 7psi
(in reply to sacicons)
Post #: 9
RE: Clutch and flywheel - 4/20/2008 8:01:22 PM
lawlersauce
Status: offline
quote:
ORIGINAL: EJ1Coupster64
Post #: 10
Login OR Register now to post a reply to this forum topic.
Honda Civic >> Your Ride >> Transmission & Differential
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414155
remmy11161
fiirkan10322
mill$civic8433
marty8262
mxs8005
nail i3unny7705
sacicons7674
fliphkd7207589
pete7169
New Vendors
K&N Engineering, Inc.
