d16 a/t to b16a m/t
Login | |
d16 a/t to b16a m/t - 4/4/2008 6:12:04 PM
racinggrl
Hi I have a 96' civic with a d16y7 automatic transmission, now I want to put a b16a 93'-95' in it. Can i use my same harness? and what else do I need, some ppl told me that I need a b16 distributor from newer engine .. all I have from the b16a is the engine,m/tranny & the ECU...Can someone pls help me out....thanks
RE: d16 a/t to b16a m/t - 4/5/2008 7:30:58 AM
bcivic
Yeah you will definetely need a new wiring harness if your engine comes with part of one then send the two (the one on the engine and your stock one) to rywire for them to convert it for you unless you can do it yourself. What about shift linkage and axles you will need those as well your stock axles and shift linkage will definetely not work. Since you are converting to manual your going to need a clutch and whether yours is cable or hydraulic your going to need the cable lines or hydraulic lines. Some times you will need new engine brackets to when I did my swap I didnt though. Hope the swap goes well.
_____________________________
1997 Honda civic dx engine swap b16a dohc vtec stage 3 clutch fidanza flywheel k&n intake dc sports 4-1 header high flow cat cat back lowering springs/ strut tower bar hasport motor mounts turbo coming soon hopefully
RE: d16 a/t to b16a m/t - 4/10/2008 1:16:46 PM
racinggrl
thanks for the reply, I have a other '98 civic that was in a accident,that one was d16 manual, can I use that harness?? or do I still get problems with the wiring?
RE: d16 a/t to b16a m/t - 4/10/2008 3:38:01 PM
reaper2022
You'll need a harness from a b16. You could call some local scrapyards to see if there's a wrecked 99-00 civic SI around you, or you could try ebay or forums' for sale sections. Also, what do you have exactly? Is it just the block and head? Or does it have the intake mani, exhaust mani, distributor, sensors, etc? Either way, you'll definitely need: b-series motor mounts (any b-series mounts will work fine) A t-bracket b-series shift linkage manual pedal assembly (technically, you just need the clutch pedal, but you're better off getting the clutch pedal as well as the brake/gas pedals) clutch fluid resevoir master cylinder clutch lines there's probably more, but that's all that i can think of right now
94 civic ex 01 Mustang v6 01 cbr600 F4i
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Civic Prices
Honda Civic
Civic Si Concept
Advertising Info
Contact Us |
Advertising |
Automotive Resources |
Honda Civic Links |
Archive |
About |
Legal |
Privacy Policy |
© Honda Civic Forum
