Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
98 civic muffler
  Printable Version
Honda Civic >> Your Ride >> Header, Intake, & Exhaust >> 98 civic muffler Page: [1]
Login
Message << Older Topic   Newer Topic >>
98 civic muffler - 4/5/2008 11:03:32 AM
bill_burke2004
Status: offline
I have a 98 honda civic LX. My cars muffler is completely rusted. I bought a replacement muffler and wanted to change it by myself as the repair shops quoted around $80 to just remove the old muffler and connect the new one. I am not able to remove the screws of the existing muffler. They are completely rusted and jamed. Can any one please suggest how I can remove the existing muffler from my car. Also do I have to buy new Oring and the screws or can I use the old parts from the car?
Post #: 1
RE: 98 civic muffler - 4/6/2008 5:16:40 PM
conceptualpolymer
Status: offline
If you encounter a really rusted screw, there are normally a couple of options that may work, but here's what I'd do:
1. Spray the screw with WD-40 or equivalent; let sit for 15 minutes or more.
2. Use a Dremel tool and cutoff disc to grind a slot in the screw head. The slot must be wide enough so that a decent-sized flat blade screwdriver can fit in it.
3. Remove the screw.
Option 2:
1. Use a Dremel tool to grind down the screw head.
2. Using a center punch, make a divot in the center of the screw body.
3. Drill through the screw body using a drill that is slightly smaller than the screw body.
If the screw is fairly large, you may be able to use an easy out, but that works only if you can drill a starter hole in the screw body and have enough remaining material around the side of the hole to allow the easy out to unscrew the screw.
Dave
_____________________________
1997 CX 5-speed
Eibach springs and shocks
Magnaflow cat-back
AEM V2 intake
16-inch Black Racing Pro wheels
Pillar Pod/tach/clock, Magnaflow and V2 install:
http://www.conceptualpolymer.com/honda_corner.htm
(in reply to bill_burke2004)
Post #: 2
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Honda Civic Forum >> Your Ride >> Header, Intake, & Exhaust
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414235
remmy11161
fiirkan10506
mill$civic8468
marty8273
mxs8006
fliphkd7207711
nail i3unny7705
sacicons7675
addiction2ba7354
New Vendors
K&N Engineering, Inc.
