Go Back   HondaCivicForum.com > Your Ride > ECU Tuning & Fuel Management
Reply
Old 04-07-2008, 07:47 PM
TDOTZFINEST TDOTZFINEST is offline
My Garage
Default NEED HELP>>>WILL PAY
Installed AEM intake in 2006 civic ex and now its been a few months and the engine light appears and disappears. Someone told me that i should retune it to the new intake. I brought it into the dealer just to see what they would say and they gave an explanationof something like to much air , fuel ratio.... I am not a mechanic nor have the knowledge to understand...if someone here that lives in GTA area Toronto,Ontario i will pay someone to retune my car with the new intake...or if anyone else has any suggestions.
p.s. i have checked all seals and the chip on the intake, it's fine.
your help is appreciated.
Sponsored Links
Old 04-07-2008, 07:53 PM
macbeth18288 macbeth18288 is offline
My Garage
Default RE: NEED HELP>>>WILL PAY
chip?
Check the seal on the o2 sensor
sometimes that can throw a CEL
That kind of sounds like what it is since it "appears and disappears"
__________________
JP
2001 Civic EX Coupe
MT
"Hokey religions and ancient weapons are no substitute for a good blaster at your side”
Old 04-07-2008, 08:01 PM
FlipHKD720's Avatar
FlipHKD720 FlipHKD720 is online now
My Garage
Send a message via AIM to FlipHKD720
IAT sensor man*, not o2 ^
did you reset your ECU? (disconnect your negative battery terminal for 5 minutes)
__________________
Old 04-07-2008, 08:22 PM
My Garage
IAT sensor..should i try to remove it and reisntall it wilth some type of seal??? I did the battery thing no luck . There is only 1 sensor on it right?? Its pretty tight,, but there is no form of seal around it ...should there be??
Thanks guys for your quick response.
Old 04-07-2008, 08:31 PM
My Garage
IAT or IAN flip?
__________________
JP
2001 Civic EX Coupe
MT
Old 04-07-2008, 09:02 PM
FlipHKD720's Avatar
My Garage
intake air temperature, i once called it an o2 sensor as well but MXS corrected me with the IAT.
__________________
Old 04-07-2008, 10:31 PM
My Garage
OK I gotcha.
It's just on the other post you had put IAN and I got really confused then, haha.
THanks for the info.
__________________
JP
2001 Civic EX Coupe
MT
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
Internet Brands, Inc.
