RE: tuning a mild b16 build (ITR cam/ CTR piston)
You will be able to tune fuel in all RPM ranges, in low throttle and high throttle. As long as you have a wideband, you should be ok. Although, you cannot adjust timing through the VAFC, so you will not be getting every last HP you were hoping for. I personally have the Neo, I just use that to make fine tuning adjustments for different day to day changes. Other than that, I'm tuned with Crome, tuned by me(99 EX D16 turbo'd 11psi)! I've been in your shoes before, it's easier to just go with a new EMS(obd1 P28 ecu w/Crome, Hondata, etc) and get it tuned. You will save lots of money and time in the long run...
__________________
There is no replacement for displacement, except for some boost of course....
