D16y8 A/T to B16a2 M/T!
Login | |
D16y8 A/T to B16a2 M/T! - 4/10/2008 6:34:42 PM
ClintT.
I have a 98 Civic EX and i want to swap the motor and tranny. What all exactly would I need for this? I know its gonna be a lot, but I'm still kinda learning so be kind please. Thanks
_____________________________
1998 Honda Civic Ex (Selling) AEM Short Ram Apex'i GT Spec Cat-Back Magnaflow Hi-Flow Cat DC Sport 4-2-1 Headers Front Strut Tower Bar 17" Tenzo R Shu 8
RE: D16y8 A/T to B16a2 M/T! - 4/28/2008 11:42:00 AM
bcivic
motor tranny ecu, axles, shift linkage, obd2 to obd1 conversion, new wiring harness or modified one. - those are all necessary for the swap. To convert to manual you need pedal set for manual, clutch master cylinder, hydraulic line all the way to the slave cylinder on the transimission. This is going to be a good 3k I would say other things you might want / need hasport motor mounts, short shifter, front engine torque mounts, I dont know about power steering or AC but thats what you need to get it running. A must is to swap distributor cap, rotor, wires plugs, timing belt water pump and clutch I ve done this swap before trust me its easier while its out of the car I did everything but change the clutch and 8 months later it was time for a clutch change, oh headers might be nice to do as well. good luck with the swap.
1997 Honda civic dx engine swap b16a dohc vtec stage 3 clutch fidanza flywheel k&n intake dc sports 4-1 header high flow cat cat back lowering springs/ strut tower bar hasport motor mounts turbo coming soon hopefully
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Civic Prices
Honda Civic
Civic Si Concept
Advertising Info
Contact Us |
Advertising |
Automotive Resources |
Honda Civic Links |
Archive |
About |
Legal |
Privacy Policy |
© Honda Civic Forum
