Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
Do I need to get anything else for shocks/struts/springs?
  Printable Version
Honda Civic Forum >> Your Ride >> Suspension, Brakes, Tires & Wheels >> Do I need to get anything else for shocks/struts/springs? Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
Do I need to get anything else for shocks/struts/springs? - 4/11/2008 6:29:12 AM
inthezoneac
Status: offline
I am looking at kyb shocks/struts and H&R springs, will be about $500 total. Would you recommend anything else for this setup? It's a daily driver, just want something that handles better, isn't too stiff, and lowers my car some.
Post #: 1
RE: Do I need to get anything else for shocks/struts/sp... - 4/11/2008 6:52:00 AM
bakertime
Status: online
bakertime's photo gallery
You may want to consider a camber kit to adjust the camber of your wheels back to stock.  With a mild drop, an alignment and regular tire rotation you won't have major camber wear though.
_____________________________
(in reply to inthezoneac)
Post #: 2
RE: Do I need to get anything else for shocks/struts/sp... - 4/11/2008 7:28:59 AM
inthezoneac
Status: offline
I found skunk2 front/rear camber kit bundle. It has their best front camber kit with polyurethane bushings for $360 shipped, good deal?
(in reply to bakertime)
Post #: 3
RE: Do I need to get anything else for shocks/struts/sp... - 4/11/2008 9:56:48 AM
mxs
Status: offline
mxs's photo gallery
Waste of money in my opinion.
If you live in an area with road salt, be prepared to have to cut/replace your rear shock bolts.
Driving takes 3 abilities: Accelerating+braking+turning. More power only helps acceleration. Lower weight helps all 3.
DON'T EMAIL ME W/ TECH QUESTIONS, I WILL IGNORE YOU.
Post #: 4
RE: Do I need to get anything else for shocks/struts/sp... - 4/11/2008 10:21:57 AM
inthezoneac
Status: offline
what's a waste of money, a camber kit or the kyb/h&r suspension?
(in reply to mxs)
Post #: 5
RE: Do I need to get anything else for shocks/struts/sp... - 4/11/2008 11:27:21 AM
mxs
Status: offline
mxs's photo gallery
camber kit is a waste of money. How much do the springs drop your car, 2 inches maybe? You'll be fine, just get an alignment. Read the "useful suspension information" sticky for more...
Post #: 6
RE: Do I need to get anything else for shocks/struts/sp... - 4/11/2008 2:39:29 PM
addiction2bass
Status: offline
addiction2bass's photo gallery
ya for my stech springs ruffly 2inch drop i just used 2-3 washers behind the rear upper arm which gave me pretty close to stock camber in the rear and the front wasnt really needed, only my passenger side was out of spec by like 0.1 which is nothing to worry about!
just rotate your tires regularly and it wont be any problem!
just be prepared if you do the work yourself for the rear lower control arm to be seized up... you might luck out, but chances are high youll have a problem.... wish ya luck!
but other than the springs/struts, posible strut bushing if they are seized and need to be cut, and just a alignment.
(in reply to mxs)
Post #: 7
RE: Do I need to get anything else for shocks/struts/sp... - 4/12/2008 6:52:24 AM
reaper2022
Status: offline
reaper2022's photo gallery
yeah, I'd recommend going to a dealership right now and getting new rear LCA bolts and new rear shock-mount bolts.  Maybe even get new bushings to match those bolts (perfect opportunity to switch to polyurethane bushings maybe?)... bolts and bushings (if you get poly bushings) will be somewhere around an extra $100 I believe (but its' been a while since I lowered my car)
94 civic ex
01 Mustang v6
01 cbr600 F4i
(in reply to addiction2bass)
Post #: 8
RE: Do I need to get anything else for shocks/struts/sp... - 4/12/2008 6:56:29 AM
inthezoneac
Status: offline
quote:
ORIGINAL: reaper2022
OK I don't know how everything goes together, but if the camber kit comes with bushings, are those the same ones that go with the mount bolts? Or are they completely different?
(in reply to reaper2022)
Post #: 9
RE: Do I need to get anything else for shocks/struts/sp... - 4/12/2008 7:08:43 AM
reaper2022
Status: offline
I believe they're different (not having dealt with camber kits, I don't know exactly what they come with).  But mxs is right, you don't need a camber kit.  Toe is what kills your tires when you lower your car... get an alignment after you lower it and have the toe set back to factory specs and you'll be fine.
94 civic ex
01 Mustang v6
01 cbr600 F4i
Post #: 10
Login OR Register now to post a reply to this forum topic.
Honda Civic >> Your Ride >> Suspension, Brakes, Tires & Wheels
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414258
remmy11165
fiirkan10543
mill$civic8473
marty8273
mxs8006
fliphkd7207739
nail i3unny7705
sacicons7699
addiction2ba7489
New Vendors
K&N Engineering, Inc.
