Go Back   HondaCivicForum.com > Your Ride > Suspension, Brakes, Tires & Wheels
Reply
Old 04-12-2008, 11:06 AM
BB92 BB92 is offline
Default Strut, sway, tie?
whats the difference between strut, sway and tie bars
Sponsored Links
Old 04-12-2008, 01:35 PM
mybrokenblinker mybrokenblinker is offline
Default RE: Strut, sway, tie?
they serve different purposes. Strut and tie bars serve to increase rigidity of the frame, whereas sway bars decrease the sway by acting on the suspension, not the frame.
__________________
ROTOZEY19111 (2:40:30 PM): I bought a bigass can of seafoam TRANNY treatment
ROTOZEY19111 (2:40:51 PM): and put that in my crankcase
Old 04-14-2008, 07:45 AM
do strut and tie go in different spots on the car
Old 04-17-2008, 05:56 PM
sacicons sacicons is offline
kind of. a strut bar is another name for a tie bar for your shock towers, and tie bars can go on other places too.
__________________
Quote:
ORIGINAL: Forty04
I choose the rear ending
Old 04-21-2008, 11:43 PM
khooper khooper is offline
Strut bars connect the strut towers. One in the bay and usually one in the trunk or rear deck lid (top). Lower strut bars usually connect 2 points of the chassis underneath the car, most consider them useless.
Swaybars connect the front control arms or rear control arms (usually). They act like springs to reduce body roll and help keep the wheels planted on hard turns, corners.
A tie bar can be thought of as a 'bridge' that connects ('ties' together...hence the name) the mounting points for your suspension. In essence it is a chassis brace that braces the area where the struts and/or suspension arms connect to the chassis. A car will handle best if the chassis is stiff (does not flex) and all of the flexing is done by the suspension itself.
__________________
Volvo 740 Timing Belt
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
