Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
Car off - Amp still draws power. Plz Help...
  Printable Version
Honda Civic Forum >> Your Ride >> Audio/Visual Electronics >> Car off - Amp still draws power. Plz Help... Page: [1] 2   next >   >>
Login
Message << Older Topic   Newer Topic >>
Car off - Amp still draws power. Plz Help... - 4/13/2008 11:52:50 AM
94DXProject
Status: offline
94DXProject's photo gallery
I just found out that's what was killing my battery almost daily.
I checked the amp wiring - Everything seems to be in order.
Remote wire works.  Amp power led lights up when car starts.  Light goes out when car shuts off.  But it continues to sap power for some reason.
The ground was on painted metal.  I scraped the paint and connector, then reattached the ground.  Power drain is still present.
Is there a product that can block the amp from the battery until the car has been started?
_____________________________
-GSR
-LS trans
-K&N SRI
-Pacesetter steel catback
-LS 4-disk conversion
-Dropzone suspension
-SI powerSteering
-SI guage cluster
-Custom cargo cover
-15" Konigs
Post #: 1
RE: Car off - Amp still draws power. Plz Help... - 4/13/2008 12:15:18 PM
danomatic93
Status: offline
danomatic93's photo gallery
That's what your remote wire does. I wonder if your amp is malfunctioning IF you are sure you connected the remote wire correctly.
Build Thread: http://www.hondacivicforum.com/m_576697/tm.htm
For Sale Thread: http://www.hondacivicforum.com/m_558867/mpage_1/key_/tm.htm#559090
Bob Saget!
(in reply to 94DXProject)
Post #: 2
RE: Car off - Amp still draws power. Plz Help... - 4/13/2008 12:47:30 PM
94DXProject
Status: offline
It's possible.  I've heard some amps have that problem.  RE The remote wire being connected properly:  I couldn't say for sure.  I had it installed at a stereo/alarm shop.
< Message edited by 94DXProject -- 4/13/2008 12:56:34 PM >
-GSR
-LS trans
-K&N SRI
-SI powerSteering
-SI guage cluster
-Custom cargo cover
-15" Konigs
(in reply to danomatic93)
Post #: 3
RE: Car off - Amp still draws power. Plz Help... - 4/13/2008 1:12:13 PM
soloxcivic
Status: offline
ide check the remote wire but it its still a big deal u could get a battery changer and that is like a switch that u can make it so it would cut the + power
Post #: 4
RE: Car off - Amp still draws power. Plz Help... - 4/13/2008 1:28:09 PM
danomatic93
Status: offline
The remote wire SHOULD be connected behind the cd player to a blue wire. What cd player make/nodel do you have?
Bob Saget!
(in reply to soloxcivic)
Post #: 5
RE: Car off - Amp still draws power. Plz Help... - 4/13/2008 2:57:52 PM
addiction2bass
Status: offline
addiction2bass's photo gallery
with a simple 12volt light tester or multimeter check the remote turn on wire and see if it has power when the car is off.... if so your remote wire is not hooked up correctly... just because a stereo shop did it doesnt mean they did right... small shops are lazy as hell! they could have easily ran the wires and shorted the remote wire onto the power wire somewhere under a trim panel cuting the two wires.....
but if you really want your amplifiers power wire killed then go buy a solenoid any auto shop will have them. i know they use them on fords around the 80s.....
or try a audio shop for them....
heres a example...
http://www.oznium.com/relay80
but they are out of stock right now..... you wire that up next to the battery AFTER the main fuse and run a small remote wire either off the radios remote turn on wire OR just to the ignitions ACC position..... either will work fine. BUT if your remote wire is still geting power then something is either BAD or shorted on some metal somewhere....
easiest way for you is go back to stereo shop and complain your @SS OFF!!!!!!!! and make them fix it free of charge!
Post #: 6
RE: Car off - Amp still draws power. Plz Help... - 4/13/2008 3:26:29 PM
macbeth18288
Status: offline
quote:
ORIGINAL: addiction2bass
heres a example...
^+1
Make the shop make it right.
JP
2001 Civic EX Coupe
MT
"Hokey religions and ancient weapons are no substitute for a good blaster at your side”
(in reply to addiction2bass)
Post #: 7
RE: Car off - Amp still draws power. Plz Help... - 4/13/2008 3:38:13 PM
mk378
Status: offline
Disconnect the remote wire entirely at the amp.  Then if it's still drawing power the amp is defective.
(in reply to macbeth18288)
Post #: 8
RE: Car off - Amp still draws power. Plz Help... - 4/13/2008 5:25:11 PM
94DXProject
Status: offline
quote:
ORIGINAL: danomatic93
The head unit is a Sony.  I forget the model number, but it's the one with the flip-down screen that goes stealth black when the car is turned off (the MP3 version).  I checked the blue remote wire.  It's connected where it should be on the HU.
quote:
ORIGINAL: macbeth18288
heres a example...
^+1
This may come as a shock, but those suckers closed down. lol
quote:
ORIGINAL: mk378
Bingo!  Disconnected and still drawing power.  I guess I have one of those faulty amps that was mentioned earlier.  Other than murdering batteries it works great.
addiction2bass...Thanks for the link.  I'll be getting me a relay soon.  And thanks for all the help, fellas.
-GSR
-LS trans
-K&N SRI
-SI powerSteering
-SI guage cluster
-Custom cargo cover
-15" Konigs
(in reply to mk378)
Post #: 9
RE: Car off - Amp still draws power. Plz Help... - 4/13/2008 7:07:53 PM
addiction2bass
Status: offline
ya  thats why these small shops are not worth saving cash by using... they all go under so quick or they SUPOSEDLY have a new owner and change there name so any old warentes they might have SAID are good are GONE...
ill stick with ebay or direct ;) sellers ratings on ebay are harder to get higher. the higher the better seller.
Post #: 10
Login OR Register now to post a reply to this forum topic.
Honda Civic >> Your Ride >> Audio/Visual Electronics
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414258
remmy11165
fiirkan10543
mill$civic8473
marty8273
mxs8006
fliphkd7207739
nail i3unny7705
sacicons7699
addiction2ba7489
New Vendors
K&N Engineering, Inc.
