Amp Installation
Login | |
Amp Installation - 4/13/2008 1:00:27 PM
hamesworth
Alright, I think I am about to run the wires for my sub and amp. Are there any tips or tricks you guys would offer before I go and install them in my 07 civic w/ nav?
RE: Amp Installation - 4/13/2008 1:09:35 PM
soloxcivic
make shure nothing will cut the wire inside the car... if ur going to make a hole in the firewall make shure u have that sealed up after other then that idk what other tips will help unless ur going to run the wire under the car
RE: Amp Installation - 4/13/2008 1:11:19 PM
94DXProject
You're gonna install an amp and sub to your nav system???
_____________________________
-GSR -LS trans -K&N SRI -Pacesetter steel catback -LS 4-disk conversion -Dropzone suspension -SI powerSteering -SI guage cluster -Custom cargo cover -15" Konigs
RE: Amp Installation - 4/13/2008 1:13:43 PM
hamesworth
no i only put nav so you would know what kind of head unit i had.
RE: Amp Installation - 4/13/2008 3:33:56 PM
macbeth18288
Is this a stock head unit?
JP 2001 Civic EX Coupe MT "Hokey religions and ancient weapons are no substitute for a good blaster at your side”
RE: Amp Installation - 4/13/2008 3:34:56 PM
hamesworth
yes it is the factory HU w/ nav
RE: Amp Installation - 4/13/2008 3:59:57 PM
macbeth18288
Have you already found a way to wire the amp to the head unit, or are you just going to connect into speaker wires. In other words, in there a sub output or any pre-outs in the back of the head unit?
RE: Amp Installation - 4/13/2008 4:03:27 PM
hamesworth
There is an 8" sub in the rear deck. i think I am going to use a line out inverter from that.
RE: Amp Installation - 4/14/2008 3:52:14 PM
imshirazy
quote:
ORIGINAL: hamesworth Alright, I think I am about to run the wires for my sub and amp. Are there any tips or tricks you guys would offer before I go and install them in my 07 civic w/ nav? Sure. Run the power wire and RCA cables separate from each other, they don't have to be on the other side of the car, but at least a good foot or so. If you want, upgrade to shielded cable to avoid picking up outside signal or causing interference. Try to keep the wires away from any other signal or charge emitting device such as other cables, lights, gauges, etc. Use a sufficient power and ground thickness, the more the merrier. Upgrade to the "big 3" which consists of a larger alt to batt wire, and better ground Make your cables/wires as short as possible, this allows for less resistance and less outside signal to pick up The thicker and smaller the ground cable from the amp the better, try to keep it within 15 inches, and it should be as thick as the power cable. Properly clamp down the ends of all power or ground sources, make sure you don't ground your amp by screwing into the wire ends. Don't keep your amplifier in a location that it cannot get ventilation Do not attach your amp to your sub box Use sufficient sized speaker wire as well
burntheplanets.com/forum my website!
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Civic Prices
Honda Civic
Civic Si Concept
Advertising Info
Contact Us |
Advertising |
Automotive Resources |
Honda Civic Links |
Archive |
About |
Legal |
Privacy Policy |
© Honda Civic Forum
