Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
B series hybrid swap!!!!
  Printable Version
Honda Civic >> Your Ride >> Engine & Internal >> Swap Meet >> EG Swaps >> B series hybrid swap!!!! Page: [1]
Login
Message << Older Topic   Newer Topic >>
B series hybrid swap!!!! - 4/19/2008 1:34:34 PM
fast95hatch
Status: offline
i have a 95 civic coupe...im building a Ls Vtec for it...it has a b18a1 block, b16a head, b16 tranny...i need to know which L bracket to use for the rear and which front tranny bracket to use...do i use 94-01 integra brakets or can i use 99-00 civic si brackets or do i use the 90-93 integra brackets??? does it matter which brackets i use if i swapped out to use a gsr tranny, or r all b series brackets the same???
Post #: 1
RE: B series hybrid swap!!!! - 4/19/2008 5:26:56 PM
sacicons
Status: offline
sacicons's photo gallery
94-01 integra, except the one that mounts the ac compressor, thats del sol/si. as long as its hydro/hydro, the tranny mounts are the same for b series.
_____________________________
quote:
ORIGINAL: Forty04
I choose the rear ending
(in reply to fast95hatch)
Post #: 2
RE: B series hybrid swap!!!! - 4/20/2008 9:43:11 AM
fast95hatch
Status: offline
yea i thought that the tranny brackets were the same but the 99-00 civic si tranny brackets have a different part number than the 94-01 integra, so that made me have seconds thoughts.
Post #: 3
RE: B series hybrid swap!!!! - 4/20/2008 10:29:17 AM
sacicons
Status: offline
really? ive swapped mine around a few times and never noticed a difference. never done a side by side comparo though. but i have swapped teg/b16 trannys back and forth without having to change mounts. damn, its been too long since i did my swap to remember what mounts i ordered. ill do some research and get back to you.
quote:
ORIGINAL: Forty04
Post #: 4
RE: B series hybrid swap!!!! - 4/20/2008 10:50:27 AM
sacicons
Status: offline
it seems to me that all of them for a 92-95 should come from the teg, except the one for your AC, since the teg ac pump has a different bolt pattern. the 99-00 si pump is the same as the d series. 96-00 use the si mounts.
quote:
ORIGINAL: Forty04
(in reply to sacicons)
Post #: 5
RE: B series hybrid swap!!!! - 4/23/2008 5:19:46 PM
fast95hatch
Status: offline
thanks for researching it for me...i appreciate it...
but im still wondering on wut injector to use with my setup...i was gonna go with the rc 310cc injector...but should i go with peak and hold or saturated??...if i go peak and hold, then will i need a resister box??...im gettin my p28 ecu chipped, so by me having it chipped, will it be ok to run peak and hold without using a resistor box?
Post #: 6
RE: B series hybrid swap!!!! - 4/23/2008 6:02:05 PM
sacicons
Status: offline
go saturated, and screw the chip. get a Hondata and get it fully tuned, on a Dynapack if possible. it will run and drive better than a generic chip. are you still using the stock fuel pump?
quote:
ORIGINAL: Forty04
Post #: 7
RE: B series hybrid swap!!!! - 4/24/2008 1:16:49 PM
fast95hatch
Status: offline
ima go with a walbro fuel pump 255lph
Post #: 8
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Honda Civic Forums >> Your Ride >> Engine & Internal >> Swap Meet >> EG Swaps
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414258
remmy11165
fiirkan10543
mill$civic8473
marty8273
mxs8006
fliphkd7207739
nail i3unny7705
sacicons7693
addiction2ba7482
New Vendors
K&N Engineering, Inc.
