Ground Control coilover question... HOW DO YOU INSTAL THEM CORRECTLY?
Login | |
RE: Ground Control coilover question... which do i have? - 4/19/2008 5:24:25 PM
addiction2bass
or was it KONI YELLOWS that are highly recomended? im thinking yellows now that i start looking at them and they are externaly adjustable....
_____________________________
RE: Ground Control coilover question... which do i have? - 4/19/2008 8:42:36 PM
mxs
44 = 250# 61 = 350# those are standard rates, pretty soft, the stiffer ones are supposed to go in the front (higher number) You just need an allen wrench to adjust them, I think it's 3/16"
Driving takes 3 abilities: Accelerating+braking+turning. More power only helps acceleration. Lower weight helps all 3. DON'T EMAIL ME W/ TECH QUESTIONS, I WILL IGNORE YOU.
RE: Ground Control coilover question... which do i have? - 4/19/2008 8:49:52 PM
civicexracer
180.64.44 = 7" height x 2.5" diameter x 250 lbs/ft 180.64.61 = 7" height x 2.5" diameter x 350 lbs/ft those springs are fine for daily. to adjust, just need the right size allen key, loosen the spring perch a bit, and adjust. very easy and fast to do. Koni yellows are externally rebound adjustable.
proud member of Rubber Duckie Racing -> www.rubberduckieracing.com
RE: Ground Control coilover question... which do i have? - 4/20/2008 2:27:22 AM
addiction2bass
sweet that makes me really happy lucked out on the spring rates! so do you guys think i even need the wrench for them? or should i be able to just lower the perches with my hands after i loosen the allon screw? i keep looking at them like DAM I WANNA SLAP THEM ON.LOL but i dont want to pay for so many alignment jobs after i get new struts... i was thinking about the GC top hats... and now not sure if i want them quite yet or not... can i buy those at any time and instal them? i dont think those would effect the alignment because it looks like the spring perches are the same, looks like it just raises the shocks bolt for more travel... so i might just hold off on those quite yet.... i might not even need them... i dont really plan on super slaming the car...
RE: Ground Control coilover question... which do i have? - 4/20/2008 6:10:22 AM
reaper2022
If you don't plan on slamming the car, I don't see why you'd need tophats unless you just want extra bling. And the allen wrench is a pretty common size (not sure, but 3/16" like mxs suggested sounds about right). Once you loosen the screw in the perch, you can turn the perch by hand... GC springs don't come with those nice little wrenches most other coilovers do... they're made to be turned by hand.
94 civic ex - For Sale! 01 Mustang - AEM dryflow filter, Hella xenon headlight bulbs 01 cbr600 F4i - too much to list
