Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
Back Fire
  Printable Version
Honda Civic Forum >> Your Ride >> Header, Intake, & Exhaust >> Back Fire Page: [1]
Login
Message << Older Topic   Newer Topic >>
Back Fire - 4/20/2008 1:43:58 AM
z_dizzlemang
Status: offline
I just put on a header and full greddy Evo 2 exhaust on the car, when at high rpms and im letting the rpms slow me down im getting small pops from the exhaust, something wrong?
Post #: 1
RE: Back Fire - 4/20/2008 7:36:40 AM
SilverSedan
Status: offline
nope, likely the stock exhaust you had on there was doing a good job of killing the noise (the muffler and resonater especially). Now that you have a better-flowing exhaust thats set more for performance then for comfort, you'll hear stuff like that more.
_____________________________
97 Sedan D16Y7 5spd...stock
(in reply to z_dizzlemang)
Post #: 2
RE: Back Fire - 4/20/2008 7:48:18 AM
sacicons
Status: online
sacicons's photo gallery
you may have a very small leak somewhere, but if they are just very small pops, then thats probably normal.
quote:
ORIGINAL: Forty04
I choose the rear ending
(in reply to SilverSedan)
Post #: 3
RE: Back Fire - 4/22/2008 12:37:28 AM
khooper
Status: offline
back fire can be caused by different faults. first is to much fuel because of worn carburetter, or wrong adjusments on carburetter. choke sticking will cause backfire. timing be out of adjustment will cause backfire exhaust leak can cause backfire. bad spark plugs, or plug leads , distributer cap worn of cracked will cause backfire as for fuel in muffler, if it combusted in muffler , the muffler would split open it is not that. and i dont know of any rubber on an exhaust that would take the heat aexhaust manifold gaskets could be problem but if they were rubber they would melt
_______________
Nissan Fuel Pump
Post #: 4
RE: Back Fire - 4/23/2008 8:22:40 PM
monkeydude3
Status: offline
I didn't know these mentioned Civics had carburetors.
Any time you change your exhaust the muffler is going to have a significantly different back pressure and flow than the stock one and you will hear a lot more noises.
If you are in 4th gear say and put your foot to the floor, if you don't hear any leaks you are probably all right.
(in reply to khooper)
Post #: 5
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Honda Civic >> Your Ride >> Header, Intake, & Exhaust
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414258
remmy11165
fiirkan10543
mill$civic8473
marty8273
mxs8006
fliphkd7207739
nail i3unny7705
sacicons7699
addiction2ba7489
New Vendors
K&N Engineering, Inc.
