Rubbing on 16s! Help!
Login | |
Rubbing on 16s! Help! - 4/21/2008 10:05:39 AM
theShamgod
99 Civic Si recently added...b&g springs16s205/45/16 sometimes it does on turns. it definitely rubs in the rear while i have passengers. i thought id be fine with any situation on 16s instead of 17s, of course. i really do not want to roll my fenders. any suggestions on how to fix?
RE: Rubbing on 16s! Help! - 4/21/2008 10:14:02 AM
macbeth18288
What is the offset on the wheels? 4x100 +what?
_____________________________
JP 2001 Civic EX Coupe MT "Hokey religions and ancient weapons are no substitute for a good blaster at your side”
RE: Rubbing on 16s! Help! - 4/21/2008 1:58:36 PM
reaper2022
yeah, offset has quite a bit to do with you rubbing... just looking at it, the tire size seems right for a 16x7 wheel, and with the right offset, a 7 inch wide wheels shouldn't rub in rear.
94 civic ex 01 Mustang v6 01 cbr600 F4i
RE: Rubbing on 16s! Help! - 4/21/2008 2:12:48 PM
addiction2bass
dito... whats the rims offset.... most likely your tires are geting cut up very bad on the outter top edges.. ALSO how much have ya lowered the car? cause on stock suspension it shouldnt rub! either sell the rims and get the right offset ones OR if they dont rub to much.. roll the fender lips! just depends HOW BAD the offset is..... i rolled my rear fender lips.. http://www.hondacivicforum.com/m_455652/tm.htm
RE: Rubbing on 16s! Help! - 4/21/2008 5:13:29 PM
theShamgod
i see. im sure it's the offset then by the looks of your replies. what should the offset be? i dont know what my offsets are. is there a way to measure, or is the measurement displayed somewhere on the tire? i basically asked a mechanic's suggestion on just the size of the rims i want, then he ordered them. i'm newbie, so i'm just finding out about offsets now. my rims are Grid's by Rota. you guys are very helpful in this forum.
RE: Rubbing on 16s! Help! - 4/21/2008 5:24:53 PM
reaper2022
Basically, the offset is the distance from the back of the mounting pad (what goes up against the brake when you mount the wheel on the car) to the wheel's centerline. You can measure it, but I'm sure it's not an easy thing to do. Most manufacturers stamp the offset on the back of one of the spokes of the wheels. To avoid rubbing, the offset should be at least +38mm, ideally something between +40 and +45.
RE: Rubbing on 16s! Help! - 4/21/2008 6:38:48 PM
addiction2bass
dito..... pull one wheel off and simply look at the back of the mounting point or the spokes.... they should have stampings on them... like this...... my offset is 42 its got quite a bit of info stamped onto the rim.
