Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
Steering wheel vibrates
  Printable Version
Honda Civic Forum >> Your Ride >> Suspension, Brakes, Tires & Wheels >> Steering wheel vibrates Page: [1]
Login
Message << Older Topic   Newer Topic >>
Steering wheel vibrates - 4/21/2008 6:37:42 PM
ian125
Status: offline
I had 4 falken ziex 512s, but my two fronts wore away prematurely due to bad wheel bearings in the front. I had those replaced, and I just put on 2 brand new falken ziex 912s (the discontinued 512s became the 912s). Anyways, same size, profile, everything...I had em mounted and balanced, but now my steering wheel vibrates, its insane above 60mph. Air pressure is good. Rotors and pads were replaced not to long ago either..
My questions are, what could it be? Maybe they werent balanced right? Was I suppose to have the new tires put on the back, and the backs moved to the front?
thanks guys!
Post #: 1
RE: Steering wheel vibrates - 4/21/2008 7:44:47 PM
sacicons
Status: offline
sacicons's photo gallery
sounds like a major mistake on the replacemnet of the wheel bearings. maybe try swapping fronts for rears and see if it seems to follow the tires, but im thinking they did something wrong.
_____________________________
quote:
ORIGINAL: Forty04
I choose the rear ending
(in reply to ian125)
Post #: 2
RE: Steering wheel vibrates - 4/21/2008 7:53:18 PM
civicexracer
Status: offline
civicexracer's photo gallery
when do the vibrations occur? low speeds, high speeds, constantly? does it pull to a side when going straight? does the car shake alot while at idle and/or does the motor move alot? is there play in the steering wheel, ie: turn the wheel and it dosnt react as quickly as it should?
proud member of Rubber Duckie Racing -> www.rubberduckieracing.com
(in reply to sacicons)
Post #: 3
RE: Steering wheel vibrates - 4/21/2008 8:04:06 PM
ian125
Status: offline
I should of mentioned about the wheel bearings. I dont believe that is at fault, when i had the 512s on with the new bearings, it rode great. I only got new tires because tread was running low. So the only variable that has occured would be additon of 2 new front tires.
Car does not shake, nor pull to a side. Motor does not shake much. Vibration is noticeable 40-60. Then anything after 60mph my arms and hands shake too...  I'm gonna have em re balance it tommorrow. Hope that solves it...
< Message edited by ian125 -- 4/21/2008 8:13:25 PM >
(in reply to civicexracer)
Post #: 4
RE: Steering wheel vibrates - 4/21/2008 8:11:00 PM
bakertime
Status: offline
bakertime's photo gallery
Sounds like a balancing issue.  Talk to the shop that did it for you and have them fix it.
Post #: 5
RE: Steering wheel vibrates - 4/21/2008 8:21:33 PM
sacicons
Status: offline
yeah, then its a tire install problem. take it back to them asap. if you wait too long, they will try to get out of the responsibility for it.
quote:
ORIGINAL: Forty04
(in reply to bakertime)
Post #: 6
RE: Steering wheel vibrates - 4/21/2008 9:55:18 PM
civic_burns_all
Status: offline
civic_burns_all's photo gallery
that would happen to my pathfinder until i just got it fixed. its mostly like your wheel alignment is messed up. get it fixed
I''ll Be Back in 2010 Arnold Style
Post #: 7
RE: Steering wheel vibrates - 4/22/2008 12:28:45 AM
khooper
Status: offline
  • CV joint could cause this.
  • Or a bent rim, which balancing will not fix.
  • Check the lug nuts on all your tires. That did it for me.
  • Shaking could also occur from camber being ofset as well as all! The other answers given above.
  • Just had the same thing and it turned out to be worn struts which had caused my tire to wear unevenly (flattening one side of the tire). That caused shimmy at higher speeds.
  • Also try new CV boots or a driveshaft replacement
Brake Dust Shields Parts
Post #: 8
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Honda Civic >> Your Ride >> Suspension, Brakes, Tires & Wheels
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414259
remmy11165
fiirkan10544
mill$civic8473
marty8273
mxs8006
fliphkd7207739
nail i3unny7705
sacicons7699
addiction2ba7491
New Vendors
K&N Engineering, Inc.
