Static coming from rear speakers with volume at 0
Login | |
Static coming from rear speakers with volume at 0 - 4/23/2008 6:41:36 PM
inthezoneac
If I have my volume on low or at 0 I can hear static from my rear speakers. If I turn it up it goes away, but I'd like to fix this issue. Anyone know what it can be? running boss 5 ch amp, rear boston 6x9 speakers, everything is connected, no loose wires.
RE: Static coming from rear speakers with volume at 0 - 4/23/2008 7:51:57 PM
macbeth18288
Aftermarket radio or stock
_____________________________
JP 2001 Civic EX Coupe MT "Hokey religions and ancient weapons are no substitute for a good blaster at your side”
RE: Static coming from rear speakers with volume at 0 - 4/23/2008 8:44:13 PM
civic96lx
gains too high??
RE: Static coming from rear speakers with volume at 0 - 4/23/2008 9:16:18 PM
civicduty96
get rid of the boss amp
only a fool judges life by what he sees in other peoples eyes 96 civic 99-00 front end VIS CF hood jdm sir ll swap stage 2 ACT clutch OBX LSD T25 turbo @ 8psi FMIC hondata s300 AEM wide band AEM fuel rail sparco torinos
RE: Static coming from rear speakers with volume at 0 - 4/24/2008 3:47:23 PM
inthezoneac
boss amp works fine, I'm not putting my stuff as loud as it goes. sony cdx-gt520 radio I turned down everything for the rear speakers from the amp and I still hear the same constant static. Once I put volume at 10 or so where it's not quiet, you can't hear it, but it's going to bother me because it is there
< Message edited by inthezoneac -- 4/24/2008 4:16:28 PM >
RE: Static coming from rear speakers with volume at 0 - 4/25/2008 7:59:45 AM
cvcrcr99
Joined: 8/24/2007 From: West Chester, PA Status: offline
Do you have a Capacitor? (sp?) If not, your alternator may be running harder in order to power the amp connected to your battery making a distortion noise. You dont hear it from your speakers when you have the music up because music is coming out of the speakers, overriding the distortion noise. If you shut off the head unit completely, does the noise go away? Good Luck.
99 Civic Coupe D16y8 Crower Stg 2 Cam, SuperTech Springs & Retainers, ARP Head Bolts & Studs, Cometic HG, Ebay CAI, Black 4-2-1 DC Header, Skunk2 Short Shifter & Knob, Skunk2 IM, Hondata IM Gasket, Black Housing Headlights
