HondaCivicForum.com
-   Nitrous, Super Chargers, & Turbos (https://www.hondacivicforum.com/forum/nitrous-super-chargers-turbos-13/)
-   -   new to boost need some help, buildin nasty eg (https://www.hondacivicforum.com/forum/nitrous-super-chargers-turbos-13/new-boost-need-some-help-buildin-nasty-eg-64524/)
nastyegb18 Apr 25, 2008 11:57 AM
i currently plan on building a b18 series honda engine with a b16 gsr head and swapping it into a 1992 honda civic hatchback. i am goin to have my engine sent to laskey racing for all of the following to be done.
Benson sleeved block
Benson balanced and micropolished crank
CP pistons and rings (prolly 9:1, possibly 9:7:1 im not sure what to use)
Pauter rods
ACL bearings
OEM (TypeR) oil pump
Lower gasket set
Blueprint and assembly
Boxing, return shipping and insurance
all this crap is gonna be crazy expensive like 3500 just for that but its guarenteed to withstand 50lbs of boost, and money is not gonna be an issue im gonna be saving up and building over a year or so
i used an online horsepower from boost calculator and figured around 200hp with 30lbs of boost will produce 600 hp, if yall wouldnt mind could you tell me all what else im gonna need to get, injector size, fuel pump size, cams, tuning/ecu? im pretty sure im gonna have to get a aftermarket crank too.
also i am probably gonna run around 10lbs of boost normally and just crank it up for the track, would i be able to do this or am i gonna have to have it tuned to run a certain psi all the time?[/align]
inthezoneac Apr 25, 2008 01:20 PM
RE: new to boost need some help, buildin nasty eg
ORIGINAL: nastyegb18
Pauter rods
ACL bearings
Lower gasket set
if you're going to spend $3500 for all that why not just get a built engine for that price?
GReddy_Civic Apr 25, 2008 02:56 PM
ORIGINAL: inthezoneac
Are you serious, or just that retarded?
civicduty96 Apr 25, 2008 04:28 PM
theres no such thing as a b16 gsr.... a gsr is a b18 integra motor ....
nastyegb18 Apr 25, 2008 08:44 PM
ORIGINAL: civicduty96
have you ever heard of a poor man's gsr
look it up
and inthezoneac that is whats happenin, all i have to do is send them the b18 block and they build it into a race engine
gsumano Apr 25, 2008 09:15 PM
What he means, is adding a gsr head to a b16 block.
Live_4it Apr 25, 2008 09:26 PM
Good luck, your going to have to really know your stuff if your aim is going to be that much power.
nastyegb18 Apr 26, 2008 04:42 AM
thats the problem i dont know my stuff...ive been reading and reading, but still id like some imput from a couple people who have actually done it, and im really only looking for 400whp 600 is way too much....well not really but you get my drift
reaper2022 Apr 26, 2008 08:24 AM
I thought the b16 head outflowed the b18c head? I could be wrong though. And just so you know, you're going to have some serious traction issues (even with "only" 400hp).
Also, as a side note, it doesn't matter how much boost you're making. 10 psi on a 14b is different than 10 psi on a t3/t4. What matters is how much power you're making.
Mr Mobsta Man Apr 26, 2008 10:19 AM
Please post the carnage pictures of the car after you wreck it.
