new to boost need some help, buildin nasty eg
Login | |
new to boost need some help, buildin nasty eg - 4/25/2008 12:57:35 PM
nastyegb18
i currently plan on building a b18 series honda engine with a b16 gsr head and swapping it into a 1992 honda civic hatchback. i am goin to have my engine sent to laskey racing for all of the following to be done. Benson sleeved block Benson balanced and micropolished crank CP pistons and rings (prolly 9:1, possibly 9:7:1 im not sure what to use) Pauter rods ACL bearings OEM (TypeR) oil pump Lower gasket set Blueprint and assembly Boxing, return shipping and insurance all this crap is gonna be crazy expensive like 3500 just for that but its guarenteed to withstand 50lbs of boost, and money is not gonna be an issue im gonna be saving up and building over a year or so i used an online horsepower from boost calculator and figured around 200hp with 30lbs of boost will produce 600 hp, if yall wouldnt mind could you tell me all what else im gonna need to get, injector size, fuel pump size, cams, tuning/ecu? im pretty sure im gonna have to get a aftermarket crank too. also i am probably gonna run around 10lbs of boost normally and just crank it up for the track, would i be able to do this or am i gonna have to have it tuned to run a certain psi all the time?
RE: new to boost need some help, buildin nasty eg - 4/25/2008 2:20:37 PM
inthezoneac
quote:
ORIGINAL: nastyegb18 i currently plan on building a b18 series honda engine with a b16 gsr head and swapping it into a 1992 honda civic hatchback. i am goin to have my engine sent to laskey racing for all of the following to be done. Benson sleeved block Benson balanced and micropolished crank CP pistons and rings (prolly 9:1, possibly 9:7:1 im not sure what to use) Pauter rods ACL bearings OEM (TypeR) oil pump Lower gasket set Blueprint and assembly Boxing, return shipping and insurance all this crap is gonna be crazy expensive like 3500 just for that but its guarenteed to withstand 50lbs of boost, and money is not gonna be an issue im gonna be saving up and building over a year or so i used an online horsepower from boost calculator and figured around 200hp with 30lbs of boost will produce 600 hp, if yall wouldnt mind could you tell me all what else im gonna need to get, injector size, fuel pump size, cams, tuning/ecu? im pretty sure im gonna have to get a aftermarket crank too. also i am probably gonna run around 10lbs of boost normally and just crank it up for the track, would i be able to do this or am i gonna have to have it tuned to run a certain psi all the time? if you're going to spend $3500 for all that why not just get a built engine for that price?
RE: new to boost need some help, buildin nasty eg - 4/25/2008 3:56:01 PM
GReddy_Civic
quote:
ORIGINAL: inthezoneac if you're going to spend $3500 for all that why not just get a built engine for that price? Are you serious, or just that retarded?
_____________________________
Surf Wagon1994: might be getting a toy :D Forty4U2BNVS: I've been known to toot a pipe or two
