Wire aftermarket alarm off of the B Harness
Login | |
Wire aftermarket alarm off of the B Harness - 4/25/2008 10:41:10 PM
gunz4me
Since I am going to replace the radio and factory alarm in my 1997 Civic EX, does anyone see a problem with me using the 16P connector harness from the back of the factory radio to connect to my aftermarket alarm? I believe it has most of the triggers as well as some of the basic outputs I will need (i.e. lock all doors, unlock all doors, dome light, hood/trunk/door trigger, etc.). My project is still a couple of weeks out, but I was looking for other alternatives versus tapping the individual wires in the kick panel. I am also planning on placing the alarm where it will be a royal PITA to get to, versus the simple right under the dash approach that the so called professionals around here do. This does look right, doesn't it?
RE: Wire aftermarket alarm off of the B Harness - 5/3/2008 4:11:04 PM
KarTuneMan
Use the plug at the keyless module in the drivers kick.
_____________________________
Quit your complaining, if your stupid..... your stupid. It's not MY fault! Blame your parents.
RE: Wire aftermarket alarm off of the B Harness - 5/5/2008 7:34:41 PM
gunz4me
Thanks for that suggestion. I found the module in the service manual, and I am going to follow your recommendation! I am hoping to have all my parts in by this weekend so that I can install the Autopage RF-420LCD that I purchased to replace the failing factory alarm. I also purchased an Alpine CDA-9885 to replace the "I work when I want to" factory head unit. I have come to the conclusion that the intermittent Honda radio is probably the source of my keyless/alarm issues! I do have one final question. When my wife purchased the car in 1997, she had the dealership install the optional Honda alarm module ($175 for the unit plus $175 for the install). Can I safely remove the Honda security control unit after I remove the factory radio or should I just leave it in there? I am going on the assumption that removing the radio will render the Honda alarm useless. Oh well, I will find out soon enough...
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Civic Prices
Honda Civic
Civic Si Concept
Advertising Info
Contact Us |
Advertising |
Automotive Resources |
Honda Civic Links |
Archive |
About |
Legal |
Privacy Policy |
© Honda Civic Forum
