Go Back   HondaCivicForum.com > Your Ride > Nitrous, Super Chargers, & Turbos
Reply
Old 04-27-2008, 01:01 PM
Mossy Mossy is offline
My Garage
Send a message via ICQ to Mossy Send a message via AIM to Mossy
Default how much psi to break 300whp
Alright, so im about to buy a tial wastegate for my new setup but im kind of stuck as to what bar spring to go with. right now im between .7 bar (10.2psi), .8 bar (11.6psi), or .9 bar (13.1psi). the new setup is as follows: low comp vitara pistons, eagle forged h beam rods, all new bearing and gaskets, arp head studs, crower stage 2 turbo cam with springs and retainers, garrett t3/t04e 60 trim, etc.
what im wondering is how many psi should i shoot for to make over 300whp? i realize it will have alot to do with the tune, but im having it done by a well known tuner on an AWD Dynojet. i just want a ball park estimate. anyone?
__________________
Quote:
ORIGINAL: LEVIII
Mossy is our forum street pharmacist
"N/A = Not Acceptable!"
Sponsored Links
Old 04-27-2008, 01:07 PM
GReddy_Civic's Avatar
GReddy_Civic GReddy_Civic is offline
Spoolin' Moderator
My Garage
Send a message via AIM to GReddy_Civic Send a message via Yahoo to GReddy_Civic
Default RE: how much psi to break 300whp
Im probably wrong, but i wanna say 16ish give or take a few
__________________
Forty4U2BNVS: I've been known to toot a pipe or two
Old 04-27-2008, 01:30 PM
baron340 baron340 is offline
My Garage
what exactly does the wastegate spring have to do with it? why not just invest in a boost controller so you can change it to whatever you want?
Old 04-27-2008, 01:43 PM
reaper2022 reaper2022 is offline
Window Lickin' Moderator
My Garage
^ because with external wastegates, you can adjust the amount of boost by changing the spring.
External wastegate > Boost Controller
__________________
-2001 Ford Mustang - The DD
-1978 Fiat X-1/9 - The Resto Project
-E36 M3 or bust-
Old 04-27-2008, 02:24 PM
My Garage
^ bingo. i want my boost regulation to be precise. they call boost controllers death knobs for a reason haha.
__________________
Quote:
ORIGINAL: LEVIII
Old 04-27-2008, 09:04 PM
My Garage
so you want boost regulation to be precise along with the boost creep right? or does that not apply the same at higher levels of boost? and every reference i've ever heard to that death knob is when people get boost happy and turn it up and turn it up againand eventually over do it because they can turn it up.
Old 04-28-2008, 07:05 AM
bcrichguitars's Avatar
bcrichguitars bcrichguitars is offline
My Garage
Usually boost controllers have a limiter setting. My greddy profec b did.
__________________
95 EG - JDM D15B VTEC (LSD Tranny)
75.5mm Vitara Pistons/I-Beam Rods
TD05H 16G Evo III Turbo
Crower St. 2 Turbo Cam/Valve Springs/Titanium Retainers
Old 04-28-2008, 10:31 AM
My Garage
Maybe it's just me, but I don't like using anything that tricks my engine... o2 simulators, boost controllers, ebay chips... they're all the same to me. Personally, I think if you want to up the boost, do it the right way; don't trick an internal wastegate to think it's getting less vac than it actually is. But then again, that's just my take on it.
And I have no real proof of this, but I just don't see a boost controller as being just as reliable as an external wastegate.
__________________
-E36 M3 or bust-
Old 04-28-2008, 08:13 PM
SovXietday SovXietday is offline
My Garage
Send a message via AIM to SovXietday
...Might want to find out how boost controllers work before you comment on how they're "bad".
They're called "death knobs" because moron DSM kids stick the $40 unit on and turn up the boost because hey, more boost is fast right?
Boost controllers do not trick the engine. The engine and ECU management system knows exactly what is going on. Boost is simply controlled by when the wastegate opens, that's all the boost controller does. It changes the pressure that the wastegate opens.
60trim depending on how efficient your setup is... 15-19psi.
__________________
Champ White 1996 Civic Hatchback - 57trim SOHC
Black 1998 Z28 Camaro - LS1 M6
Old 04-30-2008, 05:11 PM
My Garage
Quote:
ORIGINAL: SovXietday
well all ive heard of them is basically what you just described about dsm kids, so i appologize for being misinformed. id still rther have a tial external wg than an internal with a boost controller.
my system should be fairly efficient since it has shiny new bearings and that stage 2 camshould give some serious lift. I think i'll try for 16 psi, and if not get a new spring and retune. thanks sov.
__________________
Quote:
ORIGINAL: LEVIII
Reply
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
