grinding into 2nd and 3rd.. please help
Login | |
RE: grinding into 2nd and 3rd.. please help - 4/30/2008 2:46:13 PM
LarsonSi_0091
it deffiently sounds like the synchros but i cant help ya one changing them i tore a tranny apart once and it blew my mind. maybe look at a haynes manual or search the net. when i have problems i have a buddy of mine do it hes a tranny guru.
_____________________________
1991 Crx Si Mods: d16z6 swap, fully built, T3/T4 .57 trim, 15 psi :) new toys recently bought: Zex 59500, crower valve springs & retainers, blox intake, 66 mm tb, traction bars, and hondata S300
RE: grinding into 2nd and 3rd.. please help - 4/30/2008 4:56:36 PM
didder
yea, my buddy is a tranny guru as well, i almost passed out when we opened it up the first time lol... does anyone know where i can locate a good synchro kit? ive been looking but i cant seem to find what i need
RE: grinding into 2nd and 3rd.. please help - 4/30/2008 5:53:23 PM
macbeth18288
Also something to think about is that you stock parts (e.g. clutch, brakes, internals) were not build for racing they were build for the average everyday driver conditions. Just hope you keep that in the back of your mind.
JP 2001 Civic EX Coupe MT "Hokey religions and ancient weapons are no substitute for a good blaster at your side”
RE: grinding into 2nd and 3rd.. please help - 5/1/2008 4:00:09 PM
didder
car is running a action 2md (500hp capable) but that sholdnt be making gears grind between shifts... any other ideas?
RE: grinding into 2nd and 3rd.. please help - 5/1/2008 11:24:14 PM
arust45
I'm encountering the same situation with my third. Grinds long and hard when shifting, except when i pop it in neutral, allow the rpms to fall, and throw in third. Lemme know if you find an inexpensive solution, cause i'm thinkin bout getting my transmission rebuilt.
97 Civic Ex Rebuilt and blueprinted d16y8 Vitara/Eagle 7.8:1 Comp Oem gasket, ARP headstuds 4puck sprung, lightened flywheel T3 .50A/R, RC440's 18psi tuned on 91 Koni, ground control, 16" SI's 2.5" turboback, Cat delete.
