Koni/GC installed, now some questions.
Login | |
Koni/GC installed, now some questions. - 4/30/2008 8:47:20 PM
TurboD
So I just got finished installing new suspension on my car, Konis with GC coilovers at 550/rear and 500/front. With Konis, how do I know if they are all the way firm or shoft? And is it normal for them to make more creeking noises then stock? Also, when the car is on the lift the suspension extends and the GC coilovers become loose, like you can grab the spring and move it up and down on the shock, is this normal? Last, my alignment is off, I know that you should get an alignment after putting new suspension in but is it normal for the steering wheel to be 1/4 out of alignment.
RE: Koni/GC installed, now some questions. - 4/30/2008 9:08:30 PM
mxs
quote:
ORIGINAL: TurboD With Konis, how do I know if they are all the way firm or shoft? They should have come with an adjusting knob, it has an arrow on it... quote:
ORIGINAL: TurboD Also, when the car is on the lift the suspension extends and the GC coilovers become loose, like you can grab the spring and move it up and down on the shock, is this normal? Yes quote:
ORIGINAL: TurboD Last, my alignment is off, I know that you should get an alignment after putting new suspension in but is it normal for the steering wheel to be 1/4 out of alignment. I guess it depends how bad your alignment was before.
_____________________________
Driving takes 3 abilities: Accelerating+braking+turning. More power only helps acceleration. Lower weight helps all 3. DON'T EMAIL ME W/ TECH QUESTIONS, I WILL IGNORE YOU.
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Civic Prices
Honda Civic
Civic Si Concept
Advertising Info
Contact Us |
Advertising |
Automotive Resources |
Honda Civic Links |
Archive |
About |
Legal |
Privacy Policy |
© Honda Civic Forum
