Internal vs external wastegates
Login | |
Internal vs external wastegates - 5/1/2008 3:16:01 PM
bcivic
I know that internal wastegates are on the turbo itself and that external wastegates are on the manifold before the turbo and they both relieve exhuast pressure in order to control boost. From what I have read external wastegates seem to be a bit more reliable so my question is is this a myth or no. I am also curious if you can run a boost controller on both of these types of wastegates or just internal wastegates? And finally assuming you dont change the boost level and leave it on what it is tuned for are Boost controllers potentially harmful can they cause a sudden boost spike destroying the engine? SHould you only change boost via different wastegate springs? Any help would be great for my turbo build this summer hopefully.
_____________________________
1997 Honda civic dx engine swap b16a dohc vtec stage 3 clutch fidanza flywheel k&n intake dc sports 4-1 header high flow cat cat back lowering springs/ strut tower bar hasport motor mounts turbo coming soon hopefully
RE: Internal vs external wastegates - 5/2/2008 11:37:27 AM
bcivic
Does anyone know?
RE: Internal vs external wastegates - 5/2/2008 12:06:33 PM
ej6buddy
only change using springs, boost controllers are bad news, especially if you like showing off (aka, upping the boost)
RE: Internal vs external wastegates - 5/2/2008 4:50:52 PM
SovXietday
Joined: 6/29/2006 From: Harleysville, PA Status: offline
quote:
ORIGINAL: ej6buddy only change using springs, boost controllers are bad news, especially if you like showing off (aka, upping the boost) Ugh. Boost controllers are a wonderful and very simple invention. They are wonderful news, I don't know the heck this place picked up the recent influx of boost controllers are bad. The only thing a boost controller does is change the boost level that the wastegate opens up at. That is it, the end. The irresponsibility of the owner who doesn't tune for the boost that he's trying to run does not make the boost controller "bad news." It just makes the owner an idiot.
Champ White 1996 Civic Hatchback - 57trim SOHC Black 1998 Z28 Camaro - LS1 M6
RE: Internal vs external wastegates - 5/2/2008 6:04:03 PM
FlipHKD720
and i'm pretty sure you can use them for both internal and extrenal
RE: Internal vs external wastegates - 5/2/2008 6:06:06 PM
gsumano
quote:
ORIGINAL: FlipHKD720 and i'm pretty sure you can use them for both internal and extrenal Yeah, you can use them on both.
Turbo d16y8 gt28r @ 7psi
RE: Internal vs external wastegates - 5/2/2008 7:16:57 PM
ej6buddy
quote:
ORIGINAL: SovXietday quote:
ORIGINAL: ej6buddy only change using springs, boost controllers are bad news, especially if you like showing off (aka, upping the boost) Ugh. Boost controllers are a wonderful and very simple invention. They are wonderful news, I don't know the heck this place picked up the recent influx of boost controllers are bad. The only thing a boost controller does is change the boost level that the wastegate opens up at. That is it, the end. The irresponsibility of the owner who doesn't tune for the boost that he's trying to run does not make the boost controller "bad news." It just makes the owner an idiot. i know there a good thing , it's just that a bunch of immature kids have been going around on here and always asking how to boost their cars, and considering they will most likely keep upping the boost, it will end up screwing up something. if they do in fact know what their doing, then i'm all for it. and yes, there are a lot of idiots in this world.
RE: Internal vs external wastegates - 5/3/2008 7:51:13 AM
reaper2022
quote:
ORIGINAL: ej6buddy i know there a good thing , it's just that a bunch of immature kids have been going around on here and always asking how to boost their cars, and considering they will most likely keep upping the boost, it will end up screwing up something. if they do in fact know what their doing, then i'm all for it. and yes, there are a lot of idiots in this world. just to add on to this, if they know what they're doing, they're obviously not going to ask about it... which is probably why you don't see many positive responses about boost controllers here.
94 civic ex - For Sale! 01 Mustang - AEM dryflow filter, Hella xenon headlight bulbs 01 cbr600 F4i - too much to list
RE: Internal vs external wastegates - 5/3/2008 8:14:35 AM
ej6buddy
quote:
ORIGINAL: reaper2022 quote:
ORIGINAL: ej6buddy i know there a good thing , it's just that a bunch of immature kids have been going around on here and always asking how to boost their cars, and considering they will most likely keep upping the boost, it will end up screwing up something. if they do in fact know what their doing, then i'm all for it. and yes, there are a lot of idiots in this world. just to add on to this, if they know what they're doing, they're obviously not going to ask about it... which is probably why you don't see many positive responses about boost controllers here. BINGO!!
RE: Internal vs external wastegates - 5/3/2008 5:00:26 PM
didder
boost controllers are freakin AWESOME... especially digital ones like on a hondata s300, apexi avcr, etc... you can put a 6 pound spring in for dding and when you feel like romping on it turn the boost up to where you were tuned at on the dyno... no more!!! example... 6pound spring, and your tuned to 15pounds, you can turn your boost controller up to the 15lbs or at 6lbs depending on how much power you feel like running, saves on your motor so you dont have to be romping on it if you dont need to be (just an opinion) basically your stuck between the minimum boost (your spring pressure) and what your max boost that your car been tuned to. any more and your an idiot, and you cant go any less so whatever. electric boost controller can actually control boost via rpm or gear, or freakin both! like 1st 6lbs, 2nd 10lbs, 3rd 15lbs etc... for better traction on launches. im really bad at explaining htings, but thats my attempt at boost controllers
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Civic Prices
Honda Civic
Civic Si Concept
Advertising Info
Contact Us |
Advertising |
Automotive Resources |
Honda Civic Links |
Archive |
About |
Legal |
Privacy Policy |
© Honda Civic Forum
