Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
Cant be convinced not to turbo
  Printable Version
Honda Civic Forums >> Your Ride >> Nitrous, Super Chargers, & Turbos >> Cant be convinced not to turbo Page: [1]
Login
Message << Older Topic   Newer Topic >>
Cant be convinced not to turbo - 5/1/2008 9:01:59 PM
civicrippa98
Status: offline
My buddy has a 98 HX with the normal bolt on's, CAI, catback, shortshifter, MSD Blaster Coil wires etc. Ne who, we all know the HX's have the D16Y5 Vtec-e, the 'e' standing for the exhaust valves on the cam being affected by v-tec. Well he wants to get a little more 'umph' out of his HX and wants to buy one of those complete turbo kits off ebay, but wants to substitute the fake t3/t4 with a t25 and compliment it with a nicer FMIC. What are your thoughts on this? Obviously, a new MAP is going to be needed, fuel pump and maybe bigger injectors depending on the amount of boost he wants, prolly 7-10psi. Do you think the stock ECU with a piggy back setup will allow the stock injectors to be used? Im not 100% sure on my honda ****, so i need help convincing him that this isnt the motor to turbo. Stock internals and 112,000 miles by the way
Post #: 1
RE: Cant be convinced not to turbo - 5/1/2008 9:25:01 PM
riceburner700
Status: offline
riceburner700's photo gallery
i would have him convert to obd1 and tune from there with like chrome or hondata. If you must stay obd2 you can use a piggy back like an afc hack or you can get a full stand alone like AEM
_____________________________
non-vtec ALL THE WAY
cylinder head guru!
(in reply to civicrippa98)
Post #: 2
RE: Cant be convinced not to turbo - 5/2/2008 11:29:19 AM
bcivic
Status: offline
Why is he bothering getting the ebay kit if he is swiching the turbo and the FMIC thats a big waste of money ebay kits are worthless as is and the manifold would almost certaintly crack so basically the ebay kit gets him nothing except maybe piping which can be bought for much less.  I wouldn't say he shouldn't turbo it just get a better kit or build it himself and I do not suggest piggyback systems get a real engine management/chipped ecu and tune it Crome would work and would be cheap.   Make sure he gets at least a compression test to see if his engine is even going to stand up to boost though.
1997 Honda civic dx
engine swap b16a dohc vtec stage 3 clutch fidanza flywheel
k&n intake
dc sports 4-1 header
high flow cat
cat back
lowering springs/ strut tower bar
hasport motor mounts
turbo coming soon hopefully
(in reply to riceburner700)
Post #: 3
RE: Cant be convinced not to turbo - 5/2/2008 12:10:01 PM
boostedct9a
Status: offline
A friend of mine got an ebay turbo kit. The Turbo itself required major porting, i had many hours put into the measuring and porting the entire hotside. The manifold being cast was probably the strongest thing in the whole kit. We eventually had to replace a bunch of stuff and it cost almost twice as much. I wouldnt do it, I would tell him to wait and save his money to get a better kit. Remember when building cars patience is key. You either do it right or do it twice.
Racing isn't a Hobby, Its a Business
2005 Evolution 8
-Precision Engineering Head
-Built Long Block
-ATP GT30R Turbo Kit
(in reply to bcivic)
Post #: 4
RE: Cant be convinced not to turbo - 5/2/2008 3:12:05 PM
SovXietday
Status: offline
SovXietday's photo gallery
Just tell him to forget about it. He'd be better off spending the money to put a different engine in it.
Champ White 1996 Civic Hatchback - 57trim SOHC
Black 1998 Z28 Camaro - LS1 M6
(in reply to boostedct9a)
Post #: 5
RE: Cant be convinced not to turbo - 5/3/2008 7:02:06 AM
civicrippa98
Status: offline
thanks for all the info, hopefully after reading this, he will change his mind. I agree with all of you, get the obdII conversion harness to obd I. i didnt realize how ****ty the ebay turbos are, i mean i knew they were ****ty come on 500 bucks for a full kit! I dunno, im prolly gonna do a motor swap with him, he found a 62,000 mile D16Z6 out of a 95 EX. I hear that these motors can go either way when you turbo them. and im assuming he will need a conversion harness to even a run a Z6 right? and probably a p28 ecu right?
(in reply to SovXietday)
Post #: 6
RE: Cant be convinced not to turbo - 6/28/2008 11:22:44 AM
Honciv801
Status: offline
yea im in the same situation...ive got a 99 hx and plan on swapin either a b16 or b18c in and boostin it (8-12 psi)...not really sure if the extra $$ is worth the bigger displacment tho...wat did ur friend end up doin then?
Post #: 7
RE: Cant be convinced not to turbo - 6/28/2008 12:42:06 PM
trustdestruction
Status: online
trustdestruction's photo gallery
quote:
ORIGINAL: Honciv801
do the b18c man. GSR swap FTW!
To the OP:
The "e" in VTEC-E does not stand for the exhaust valves being affected by VTEC. It stands for "Efficiency".
VTEC-E - Variable valve Timing and lift Electronic Control for Efficiency. This system isn''t really VTEC as we know it. At low RPM, the VTEC-E mechanism effectively forces the engine to operate as a 12-valve engine - one of the intake valves does not open fully, thus decreasing fuel consumption. At a set RPM value (i.e., ~2500RPM in the D16Y5), the VTEC-E mechanism engages the 2nd intake valve, effectively resuming operation as a normal 16-valve engine. Note: in a VTEC-E engine, there are no high-RPM performance cam profiles; this engine is supposed to be tuned for fuel economy.
1993 Honda Civic Del Sol Si
Vote for Barack Obama if you care about our country!
(in reply to Honciv801)
Post #: 8
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414235
remmy11161
fiirkan10506
mill$civic8468
marty8273
mxs8006
fliphkd7207711
nail i3unny7705
sacicons7675
addiction2ba7355
New Vendors
K&N Engineering, Inc.
