Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
Boosting an auto...
  Printable Version
Honda Civic Forums >> Your Ride >> Nitrous, Super Chargers, & Turbos >> Boosting an auto... Page: [1]
Login
Message << Older Topic   Newer Topic >>
Boosting an auto... - 5/1/2008 11:59:11 PM
civicguy2488
Status: offline
Ok here it is, i've looked for weeks now and can't get straight answers anywhere, I'm boosting a 96 EX auto, want to keep it a daily driver. What i've been told is with an auto tranny i can't turbo it due to the TCU? but i kno they make jumpers for the ECU and distr. so i can change over to OBD1, but do i have to convert to OBD1 and why if so? Any help would be so much appreciated.....
_____________________________
Boobs, Beer, and Boost....life essentials...
Post #: 1
RE: Boosting an auto... - 5/2/2008 5:07:12 AM
addiction2bass
Status: offline
addiction2bass's photo gallery
i know its not advised to boost a automatic..... the tranny will fail! it was built for the stock power and nothing more.....
i would advice a tranny swap........ or if you want more power from a motor setup look into a DOHC motor with a automatic tranny with it....
thats just my opinion then....
99 civic ex, being redone.
KONI yellows, Ground Control adjustable coilovers, for starters
(in reply to civicguy2488)
Post #: 2
RE: Boosting an auto... - 5/2/2008 11:36:04 AM
bcivic
Status: offline
The auto trannies are very weak so its not good for a turbo daily driver not to mention I dont believe they can be chipped or have any real engine management and thus cannot be properly tuned.  Change it over to a manual if you want a boosted daily driver.
1997 Honda civic dx
engine swap b16a dohc vtec stage 3 clutch fidanza flywheel
k&n intake
dc sports 4-1 header
high flow cat
cat back
lowering springs/ strut tower bar
hasport motor mounts
turbo coming soon hopefully
(in reply to addiction2bass)
Post #: 3
RE: Boosting an auto... - 5/2/2008 11:41:05 AM
BillyB98
Status: offline
Auto can be chipped just need to special order it. Ive seen plenty of boosted autos run for a long time. Get a chipped auto ecu and a good auto tranny cooler and run low boost if you want a turbo/auto. Im not telling you its the best to do but if you want an auto its definetly possible. You wont be as quick as a manual but whatev. And auto trannys can hold up to daily driving with a turbo just not stomped on all the time because that will cause the tranny to fail. So if you want an auto turbo you can get chipped obd1 ecu's and get a tranny cooler.
(in reply to bcivic)
Post #: 4
RE: Boosting an auto... - 5/2/2008 2:43:25 PM
reaper2022
Status: offline
reaper2022's photo gallery
We have/had a member who boosted their auto civic... it ran just fine until the transmission went out (which believe it or not had nothing to do with the turbo).  And why wouldn't you be able to chip an auto?  The ecu is more or less (note: I said more or less) the same as a 5-speed ecu.
What do you get when you boost an auto?  A fast automatic... nothing more, nothing less.
My car - for sale!
(in reply to BillyB98)
Post #: 5
RE: Boosting an auto... - 5/2/2008 4:40:30 PM
SovXietday
Status: offline
SovXietday's photo gallery
quote:
ORIGINAL: reaper2022
Auto ECUs have to control the transmission as well, so no, they're not the same. If they are not chipped right they become manual ECUs... and well your transmission no longer will shift.
Auto's break on stock power. It is not an if, it is a when.
< Message edited by SovXietday -- 5/2/2008 4:48:41 PM >
Champ White 1996 Civic Hatchback - 57trim SOHC
Black 1998 Z28 Camaro - LS1 M6
(in reply to reaper2022)
Post #: 6
RE: Boosting an auto... - 5/3/2008 7:57:42 AM
reaper2022
Status: offline
^ I said more or less the same, not exactly the same.  And if you take the ecu to a reputable tuner, you shouldn't have to worry about coming home with a manual ecu.
(and everything's going to eventually fail at stock power... so should we stop modifying our cars?  After all, not everyone can afford internal work)
I say boost the auto, and if/when it fails, it sounds like a good excuse to swap to a 5-speed.
My car - for sale!
(in reply to SovXietday)
Post #: 7
RE: Boosting an auto... - 5/5/2008 8:51:24 PM
SovXietday
Status: offline
You forget I ran on a stock engine for over a year dude. Engine's are one thing, but Honda auto transmissions are trash. This isn't one of those "well of course it will break eveenttuallyy"
No I mean it will break quickly, the more power you make the faster it will go. Granted, 150whp isn't really enough to break them quickly, but most reasonable Dseries turbo setups now a days are cutting into the 200s. The auto transmission WILL NOT hold that kind of power, it just won't. Engine will, yes it will wear, but it will not just give up and break like the auto transmissions will.
Believe me, I wish Honda had a good auto trans out, but they just don't.
Post #: 8
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414155
remmy11161
fiirkan10321
mill$civic8433
marty8262
mxs8005
nail i3unny7705
sacicons7674
fliphkd7207589
pete7169
New Vendors
K&N Engineering, Inc.
