Go Back   HondaCivicForum.com > General Automotive > General Civic Talk
Reply
Old 05-03-2008, 01:17 AM
Big EZ Big EZ is offline
My Garage
Default coil overs (NOT a which one should i get thread)
i dont know much about shocks and struts other than the basis on how they work. whats so special about coil overs that makes them so expensive? and what makes them better than gas or fluid filled shocks/struts?
__________________
98 Civic, 1.6L, short ram intake, full aftermarket stainless exhaust, 10.2mm plug wires, NGK plugs,
upper front and rear strut bars, smoked halo projector head lights, smoked altezza tail lights, black JDM grill
Sponsored Links
Old 05-03-2008, 02:06 AM
danomatic93's Avatar
danomatic93 danomatic93 is online now
My Garage
Send a message via AIM to danomatic93
Default RE: coil overs (NOT a which one should i get thread)
Are you talking about FULL coilovers or shocks with coliover SLEEVES?
Old 05-03-2008, 07:31 AM
inthezoneac's Avatar
inthezoneac inthezoneac is offline
My Garage
I'm pretty sure he's talking about adjustable coilovers, not shocks/struts with coilover sleeves.
__________________
Mah Civik
Old 05-03-2008, 08:02 AM
reaper2022 reaper2022 is offline
Window Lickin' Moderator
My Garage
complete coilovers:
-a ton of adjustability.... the shocks on them alone have a ton of settings (anywhere from 12-32 settings usually)
-convenience. You don't have to piece everything together.... you don't have to pull the stock suspension completely apart. You simply take off the stock struts and put the new ones on.
coilover sleeves:
-adjustable spring height
-with the right setup, they perform just as well, if not better than complete coilovers (usually for a few hundred $'s less)
__________________
Mustang Build Budget:
---I---------- <-- It's going up
Old 05-03-2008, 01:06 PM
My Garage
so what all can be adjusted? are we talking ride height and stiffness or is there something else.
__________________
Old 05-03-2008, 01:08 PM
My Garage
Some really really fancy FULL coilovers also have top hats that are able to adjust the angle at which the assembly rests at.
Old 05-03-2008, 03:48 PM
addiction2bass addiction2bass is offline
My Garage
well there are so many shocks that are different.... some are adjustable and some are not... some are internaly adjustable which can be a PITA because you have to remove the struts from the car and springs to adjust the valving.... and some have a simple knob ontop or on the sides of the struts which is AWHOLE LOT EASIER to adjust!!!!
and with the springs.... those do not change the spring rate of course you just adjust how high or low they are to set the ride height....
to find the nicest setup in your price range read the reviews.
but with any adjustable coilover you typicaly get what you pay for! make sure its a good brand! the three ive read alot from is skunk, tein, and ground controls...
ground controls seem to have the best personal choice since you can pick your spring rates.
__________________
Reply
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Advertising
Featured Sponsors
New Sponsors
K&N Engineering
© Internet Brands, Inc.
