power limit on built block on stock sleeves with ge block guard
hi, was wondein wat would be a safe figure to run my car at. im running 308 whp a tthe mo but next friday im having a gear depndant solnoid with hi low facility fitted. the gear depandant should hopefully stop the traction issues. and the hi lo will be good for everyday friving so i can lower the boost at the flick of a switch. iwas thinkin of movin u to 350 whp is this ok? i know everthin can take it i just wonder about the sleeve strength?
my setup is:
wiseco 9:1 forged pistons oversize 0.5 mm
eagle h beam rods
golden eagle block guard
arp head studs
arp main studs
cometic head gasket
t04e turbo providing boost
crome remap
255 pump
bigger injectors
sard regulaot
cheers
[IMG]local://upfiles/16048/087329B7C640474EB4B62DA1CF0770D6.jpg[/IMG]
