Honda Civic Forum   Classifieds   Photo Gallery   Member List   Calendars   Search   Contact Us   Sponsors
  Honda Civic News   Forum FAQ   Timeslips   Civic History   Recalls   TSBs   Register   Login
Charging A/C
  Printable Version
Honda Civic >> Your Ride >> Engine & Internal >> Charging A/C Page: [1]
Login
Message << Older Topic   Newer Topic >>
Charging A/C - 5/4/2008 6:45:02 PM
kyrupp7
Status: offline
Hello guys,
I got a '95 EX and the A/C is not blowing cold. Just a little colder than when just the fan. I bought a charge kid but I'm not sure exactly where to charge it. The guy at Advanced told me to put it in the valve with the "L" on the plastic cap. I tried this and it did not seem to help much. The pressure went up a small bit but not into the charged zone on the gauge. I could tell no difference in the A/C temp. There is another valve with a plastic cap labeled "H".
Do I need to charge the "H" valve as well?
Does it normally take more than one 12oz can to charge the system?
Thanks
Post #: 1
RE: Charging A/C - 5/4/2008 7:32:37 PM
JakeyMan07
Status: offline
never put it on the high side or as called H always on the L or low side and when you do it run your engine with the blower on high now when i did mine i started doing it and i saw that it was coming out on a high side line and bought a new line and then it worked but you might have a leak check all around on your lines see if you have a leak you prolly do if it is not holding pressure or the freon in there and you might want to try another can i am not sure cause some guy i talked to about it they said it takes about 4 of those cans to fill it all the way up but dont listen to me cause it could be couple of things lol just check for leaks first
(in reply to kyrupp7)
Post #: 2
RE: Charging A/C - 5/4/2008 9:15:14 PM
javon
Status: offline
which one is the l i have the blue tops is the one closer to the motor
(in reply to JakeyMan07)
Post #: 3
RE: Charging A/C - 5/5/2008 6:15:44 AM
kyrupp7
Status: offline
Thanks for the tips guys. I do think the "L" is the one closer to the engine.
A friend of mine just told me I should put a can of stop leak in it. What do you guys think?
Thanks
(in reply to javon)
Post #: 4
RE: Charging A/C - 5/5/2008 3:45:22 PM
RonJ
Status: offline
quote:
ORIGINAL: kyrupp7
The total capacity of the system is about 23 oz of refrigerant. Stop leak will only be a temporary solution, if that. Best to repair the leak.
Post #: 5
Login OR Register now to post a reply to this forum topic.
Page:   [1]
Honda Civic Forum >> Your Ride >> Engine & Internal
Jump to:
Featured Sponsors
Go
Advertising Info
Top 10 Posters
forty0414155
remmy11161
fiirkan10321
mill$civic8433
marty8262
mxs8005
nail i3unny7705
sacicons7674
fliphkd7207589
pete7169
New Vendors
K&N Engineering, Inc.
