True Noob Question-LS/VTEC?
Login | |
True Noob Question-LS/VTEC? - 5/5/2008 1:09:17 PM
BuckHijo
Joined: 4/28/2008 From: Tallahassee, Florida Status: offline
Sorry but I have a noob question, what is an LS/VTEC? I am looking at a '95 Civic EG6 with an LS/VTEC in it. Thanks for the help guys and God bless.
< Message edited by BuckHijo -- 5/5/2008 2:22:33 PM >
RE: True Noob Question-LS/VTEC? - 5/5/2008 5:37:35 PM
bcivic
an ls vtec is a sort of mini me swap. Basically its the integra 1.8 b18a or b non vtec bottom end with a DOHC VTEC head generally a b16a head because it flows so well. It can make very decent horsepower however you must watch out because ls bottom ends were not meant for 7000+ revs like b16a and b18c bottom ends. They can easily be built to take those revs and will last a LITTLE while with the stock ls bottom end. if it is really an ls vtec then it will say DOHC Vtec on the valve cover otherwise its just an ls engine. I suggest you make sure its in good condition and built correctly or else your in for major problems with that car. Hope whatever you do it goes well.
_____________________________
1997 Honda civic dx engine swap b16a dohc vtec stage 3 clutch fidanza flywheel k&n intake dc sports 4-1 header high flow cat cat back lowering springs/ strut tower bar hasport motor mounts turbo coming soon hopefully
RE: True Noob Question-LS/VTEC? - 5/5/2008 5:42:37 PM
reaper2022
The ls motor is the b18b motor, from an acura integra ls. From the factory, it's non-vtec, so what some people (well, a good many people) do is take a vtec head from a b16 or a b18c and put it on the non-vtec block, essentially making it a vtec motor. Generally, ls/vtecs are great, reliable motor, but they aren't meant to be revved as high as their factory-vtec counterparts, so if revved high on a daily basis, they become less reliable. (and thank you for being able to spell vtec correctly ) *edit: crap, bcivic beat me to it
< Message edited by reaper2022 -- 5/5/2008 5:53:15 PM >
My car - for sale!
RE: True Noob Question-LS/VTEC? - 5/5/2008 11:05:12 PM
BuckHijo
Thanks to you both for the info. What upgrades should be done to the bottom end to make it more reliable? Also should there be anything done to the ECU to make the VTEC run? or run better?
RE: True Noob Question-LS/VTEC? - 5/6/2008 10:45:52 AM
BuckHijo
Here is a list of all the mods that where done with the swap. Does this seem like it'll be reliable and run good? MODS: 96 ls block Itr oil pump Itr water pump Arp hardware Shotpeened ls rods Jdm p30 pistons 99-00 b16 head 00 itr cams Blox intake manifold Type r throttle body Dc sports 4-1 with 2.5 collector Short ram intake 99-00 si tranny with ls 5th Fidanza 7.5 flywheel Act heavy duty p/p Act solid 6 puck Weapon r radiator Ngk wires Spoon carbon kevlar spark plug wire cover Skunk 2 s/s with skunk 2 knob Testpipe Skunk 2 cat back
RE: True Noob Question-LS/VTEC? - 5/6/2008 3:22:33 PM
reaper2022
since the swap's already done and in the car, I'm willing to bet he already did the wiring (I believe there's only a few wires to run anyway) for vtec. Looking at the mods, he already touched on the bottom end a little. I'm not sure how the stock crankshaft will hold up though. By "less reliable", I didn't mean an ls/vtec will fall apart if you rev it high, I'm just saying it's obviously not going to last as long as a b18c revved to the same rpm (since the b18c was basically designed to have the s**t kicked out of it by 16-24 yo males lol). Overall, I'd say it will be a reliable engine, just don't rev the p**s out of it in every gear every chance you get. And that b16/ls transmission is a good combo... you get the quick acceleration from the b16 transmission, but then throw it in 5th and the rpms will be nice and low for cruising *edit: forgot the "t" in bet, and I figured it'd confuse you if I didn't fix it lol
< Message edited by reaper2022 -- 5/6/2008 3:30:23 PM >
My car - for sale!
RE: True Noob Question-LS/VTEC? - 5/6/2008 3:31:32 PM
BuckHijo
Yeah, from what I've read so far that combo is a pretty good set up if done right. I haven't done any research on that swap so I was just wondering what I should be looking for and what might need to be done so thanks for all the help. Now price wise is the ls/vtec swap more than say a stright b16 swap?
RE: True Noob Question-LS/VTEC? - 5/6/2008 4:22:54 PM
reaper2022
quote:
ORIGINAL: BuckHijo Now price wise is the ls/vtec swap more than say a stright b16 swap? I don't know from experience, but I'm going to say probably... especially since you have to piece it together.
My car - for sale!
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Civic Prices
Honda Civic
Civic Si Concept
Advertising Info
Contact Us |
Advertising |
Automotive Resources |
Honda Civic Links |
Archive |
About |
Legal |
Privacy Policy |
© Honda Civic Forum
